Rsync limiting bandwidth - howto
If you are like most of us, rsync is a tool you use far too much.
One issue I run into from time to time is rsync saturating a connection and reducing performance of a network for users (high CPU load).
Rsync has a built in CLI switch for regulating  bandwidth usage:
--bwlimit=5000
Appending that to your current rsync command should limit you to 5MB of throughput on the file transfer.
Typically something like this:
rsync --bwlimit=5000  [rest of CLI command]
kro
Hmm, I take it your not a huge fan on man?
--bwlimit=KBPS          limit I/O bandwidth; KBytes per second
I always crawl man pages some tools can do things you wouldn't even think of ^_^
Sure I use man from time to time.
I see other folks head bumping with cron rsync issue and other non QoS / shaped networks and dragging their stuff down.  Ideally it saves 1 person a slight headache.
Tons of features in rsync :)
kro
Oh defo, no doubt it'll save many headaches. Most likely plenty who have no idea of its existence. +1
Raymii
I like this tip! Thanks :) I can think of a few situations where this can come in handy.. My current clients however all have gigabit or higher. Not all my VPS's, so I'm going to tweak some duplicity scripts :)
zim
The Invader
Yea this is a good tip for people looking to rate some small backup scripts.. +1
