• Announcements
    • MannDude
      -MannDude
High Volume CPU VPS
13 posts in this topic
Yeah we dislike all these requests for high volume CPUs but hear me out on this one.
This is the spec I need:
8 CPU Cores (minimum, more is preferred) at 2.0 GHz minimum
512 MB RAM (1GB Preferred) (KVM because I don't think OpenVZ works for this)
20 GB HDD (An installation of Ubuntu and some calculation files)
20 GB Bandwidth (Just uploading and pulling small files here and there)
Reasoning: I need a temporary VM with high CPU usage for one week.  This high CPU usage is estimated to be about 3-4 hours about six times on the span of two-three-ish days (but could be longer).  No malicious intent, it's just that previously my dedicated servers used to be running these calculations but one of them is giving me grief and I'm almost done with everything I need.
This will be running CFD (Computational Fluid Dynamics) Modeling software.  Specifically, I'll be using OpenFOAM (http://openfoam.com).
To show an example of what I'm doing: http://imgur.com/a/ekwtP#0 (this is a very basic model that I can generate in a few seconds)
Each of those squares is a single cell, and a calculation based on what the water/fluid is doing in that square is done for each time at each iteration.  Therefore, the need for large computational power (CPU cores).
Tell me what price you guys are willing to give this for me.  I'll pay for a full month if required.
Thanks!
Share this post
Link to post
Share on other sites
Amazon? They have high CPU computing instances, hourly billing, etc.
Share this post
Link to post
How much is your budget?
Well you have to go with Dedi to be honest.
Share this post
Link to post
That's actually something I probably should have considered.  Thanks.
Yeah as I stated earlier, previously I was doing this all through dedicated servers but a situation as risen where I'd prefer to see if I can get a VM for a short time (roughly a week) instead of paying a full month of dedicated server costs (setup + rent + cancellation/etc = bigger headache).
I mean if it's possible via VPS (which I'd prefer) then fantastic.  If not then I guess I'll be left with a need for another dedicated server.
Edit:  Oh I forgot to answer the budget question.  In reality, I have set no budget.  I don't know how much people want me to pay for full use of 8 cores for short periods of time.  I'd prefer if it was below dedicated server costs but I'll weigh my options depending on what offers I can see.
Share this post
Link to post
You need a dedicated server.  Amazon has what amounts to them, but will be ridiculously expensive.  You might look at uptano.com (single tenant VPS node, billed by the hour) which I've played with and which works pretty well, though a week on Uptano might cost as much as a month on OVH (or a day on Amazon).  Keep in mind that recent x86 servers are much faster per core than older ones.  A 4-core E3-1230 is faster than an older 8-core box.
Renting for a month from OVH is no big deal.  There's no setup charge, provisioning is almost as simple as a VPS, and you don't have to cancel, just don't renew at the end of the month.
Edited by willie
Share this post
Link to post
Alright clarification on Amazon.  They only give you one virtual core.  Not really what I'm specifically looking for.
Yep that's what I'm expecting I'll have to do but I thought might as well ask around see if anyone else has anything I can snag for a week instead of having to pay for an entire month :P (not the best reasoning but meh, faster to deploy)
Share this post
Link to post
Look at the C3. type instances
  • c3.large: 3.75 GiB of memory, 2 vCPUs, 7 EC2 Compute Units, 32 GB of SSD-based local instance storage, 64-bit platform
  • c3.xlarge: 7 GiB of memory, 4 vCPUs, 14 EC2 Compute Units, 80 GB of SSD-based local instance storage, 64-bit platform
  • c3.2xlarge: 15 GiB of memory, 8 vCPUs, 28 EC2 Compute Units, 160 GB of SSD-based local instance storage, 64-bit platform
  • c3.4xlarge: 30 GiB of memory, 16 vCPUs, 55 EC2 Compute Units, 320 GB of SSD-based local instance storage, 64-bit platform
  • c3.8xlarge: 60 GiB of memory, 32 vCPUs, 108 EC2 Compute Units, 640 GB of SSD-based local instance storage, 64-bit platform
Also there was a coupon for $100 free Amazon credit floating somewhere...
Share this post
Link to post
If you only really need 2-3 days (maybe spread across more than one session) uptano.com might look a bit better.  Their 8-core box costs 23 cents an hour.  It is basically a dedicated server preconfigured to run VPS's so you don't have to go through a cumbersome dedi provisioning process.  You really can spin it up, do stuff, and shut it down in an hour.
I don't think it's feasible to compute like you're describing on normal VPS, but who knows.
Can you use a local workstation?
Share this post
Link to post
Hm... actually pretty interesting thanks.  I'll look into this.
Unfortunately because this is more of a "temporary" means our research team doesn't have our own workstation/cluster (nor really do we want to invest the proper funds).
And I'd prefer to pay a little extra and get this thing done quickly/faster instead of waiting for a week for a single calculation to pull through (a small part of our calculations running on 1 core took 8 hours to accomplish...).
Share this post
Link to post
I got this taken care of.  Someone approached me with a VPS.
Thanks!
Share this post
Link to post
Thanks!
I was just about to offer you a slice on my personal dedi, glad to see that you've got it sorted anyhow :)
1 person likes this
Share this post
Link to post
Thanks!  Yeah a few friends helped me out :)
Share this post
Link to post
