wScript: simple (running) KVM list script (RAM/CPU/VNC/HDD) for multiple nodes
William
pr0
This is the simple edition - I have a further one that takes data about the KVM from the local node by ps and alike, i will probably post it in some days/week.
This script simply SSHs into all nodes from a downloaded hostsfile (or a single host by IP/hostname), executes a local script that dumps the KVMs as variables back to the source server and then displays it.
If you want to use a local file you can simply modify the curl part.
Hostsfile format is simply "hostname,IP".
For informations it requires a secondary script (vminfo) installed on all nodes.
vminfo is very useful for own scripts as well, in special due to the VARDUMP option.
It should work on any KVM setup unless the ISO mount is before the HDD mount in the Libvirt XML (will display ISO size/path then).
Example output (vmlist):
root@computing01:~# vmlist
Host: computing01       IP: 10.76.138.10
VM: icinga      CPUs: 1 RAM: 1024 MB    VNC: 10.76.138.22:5902  HDD: /dev/zvol/ssd01/zvol_icinga / 10.7 GB
VM: ircd        CPUs: 1 RAM: 512 MB     VNC: 10.76.138.22:5903  HDD: /dev/zvol/ssd01/zvol_ircd / 10.7 GB
VM: jabber      CPUs: 1 RAM: 512 MB     VNC: 10.76.138.22:5904  HDD: /dev/zvol/ssd01/zvol_jabber / 10.7 GB
VM: mailserver  CPUs: 2 RAM: 2024 MB    VNC: 10.76.138.22:5905  HDD: /dev/zvol/ssd01/zvol_mailserver / 32.2 GB
VM: revproxy    CPUs: 1 RAM: 512 MB     VNC: 10.76.138.22:5909  HDD: /dev/zvol/ssd01/zvol_revproxy / 10.7 GB
VM: hosting     CPUs: 2 RAM: 4096 MB    VNC: 10.76.138.22:5916  HDD: /dev/zvol/ssd01/zvol_hosting / 53.7 GB
VM: monitoring  CPUs: 4 RAM: 4096 MB    VNC: 10.76.138.22:5927  HDD: /dev/zvol/ssd01/zvol_monitoring / 85.9 GB
Host: storage01 IP: 10.76.138.2
VM: ftpshare    CPUs: 1 RAM: 512 MB     VNC: 10.76.138.20:5915  HDD: /dev/zvol/storage01/kvm/zvol_ftpshare / 10.7 GB
VM: gestioip    CPUs: 1 RAM: 1024 MB    VNC: 10.76.138.20:5901  HDD: /dev/zvol/storage01/kvm/zvol_gestioip / 10.7 GB
VM: proxy       CPUs: 1 RAM: 512 MB     VNC: 10.76.138.20:5908  HDD: /dev/zvol/storage01/kvm/zvol_proxy / 10.7 GB
VM: vpn         CPUs: 2 RAM: 2048 MB    VNC: 10.76.138.20:5919  HDD: /dev/zvol/storage01/kvm/zvol_vpnvie / 10.7 GB
VM: zeyuu       CPUs: 1 RAM: 1024 MB    VNC: 10.76.138.20:5925  HDD: /dev/zvol/storage01/kvm/zvol_zeyuu / 107.4 GB
Host: storage02 IP: 10.76.138.3
VM: n2nvie      CPUs: 2 RAM: 1024 MB    VNC: 10.76.138.21:5921  HDD: /dev/zvol/storage02/kvm/zvol_n2nvie / 10.7 GB
Host: computing02       IP: 10.76.138.55
VM: win2012     CPUs: 4 RAM: 1536 MB    VNC: 10.76.138.23:5913  HDD: /dev/raid10-vol/win2012 / 96.6 GB
Example outputs (vminfo):
root@computing02:~# vminfo win2012 VARDUMP
VMNAME=win2012 VMVNCIP=10.76.138.23 VMVNCP=5913 VMCPUS=4 VMRAM=1536 VMDISK=/dev/raid10-vol/win2012 VMDISKS=96.6
Local KVM win2012
VNC IP: 10.76.138.23 Port: 5913 Combined: 10.76.138.23:5913
4 CPU cores - 1536 MB RAM
Boot disk /dev/raid10-vol/win2012 - Size: 96.6
Download vmlist:
wget --no-check-certificate https://william.si/code/vmlist
Download vminfo:
wget --no-check-certificate https://william.si/code/vminfo
