Need huge dedicated server - 72GB+ ram
HaitiBrother
Need huge dedicated server.
Current:
72GB RAM
1TB HDD
2 Intel Xeon L5520 2.26GHz
15 IPs
1TB @ 1Gbps
We're looking for a dedicated server with minimum of 60GB ram, prefer an SSD.
USA/Canada preferred. We pay roughly $130/month currently for it in USA, no ddos protection, etc.
Offers?
I used to have a server from WANSecurity with the same specs you're looking for, here's their latest promo: http://www.webhostingtalk.com/showthread.php?t=1357229
Xeon L5520 Dual Quad Core 2.26 GHz
72GB DDR3 ECC
1TB SATA or 4xBYOD Bay
2.5TB BGPGenius Premium Blended Bandwidth
1G FDX Port
CIDR /29 IP Allocation
Dedicated (Always on) IPMI with Virtual Media Included (Install your own OS support)
Remote Reboot Included
$79/month
Their network was good and their uptime was also decent (a few planned outages when I first arrived but that was it).
EDIT: I didn't see the IP requirement, for 29 IPs it's $103/month
XFS_Duke
XFuse Solutions, LLC
Did you say, 128gb of ram and stick around $150-$200 per month? If you find one like that, let us all know...
OSTKCabal
If you're running a large game server, I'd highly recommend a faster / more modern processor to keep up with CPU-related demands. Nobody likes to play on a laggy server.
Of course, this does depends on what game it is and if it has the proper ability to make use of multi-threading.
Everyday
As much as it pains me to say it, for your budget and RAM requirements you should look at ovh. Don't forget that you will get ZERO support from them so be prepared to be able to manage every aspect and if you need help you will need to get it else where.
oneilonline
We have a similar spec server on sale right now:
Dual Xeon L5520
72 GB DDR3 1333
1TB SATAIII 7200
100Mbps
10 TB
4 IPs
On-Demand KVM / IP
Seattle
24 Hrs Build
$10 more for 1TB @ 1Gbps
Of course the IPs would have to be justified.
rmlhhd
Dual Xeon L5520
72 GB DDR3 1333
1TB SATAIII 7200
100Mbps
10 TB
4 IPs
On-Demand KVM / IP
Seattle
24 Hrs Build
Your reselling with ServerStadium?
