About networking
doctorslo
Hello,
I am fairly new with running the VPS host. For now I have just one question.
Every VPS needs to have it's own IP, right? (in case when you want different people use that servers)
If I order a dedicated server, they can add up to 3 more IPs.
Now if I run 10 VPS on that machine, how I can handle it with just 4 IPs?
The most VPSs you can create with 3 IPs (4 minus 1 for the host node) is 3 VPS without using NAT and sharing IPs.
1. Every VPS does NOT need it's own Public IP. You can always NAT them.
2. If you had a Dedicated server with 3 IPs, you can install however many VMs onto it but with NAT-ed IPs. If you want 1 VPS to 1 IP then you can only have 3 VPSes on that server.
