• Announcements
    • MannDude
      -MannDude
ARM has legs. Real world use.
82 posts in this topic
12 hours ago, splitice said:
2. Lack of support. There is a general lack of binaries already compiled for ARM. Photoshop? Visual Studio? etc
The story behind ScaleWay
"We underestimated the lack of upstream kernel support with our new hardware. The SoC we were using, was usually employed in NAS servers and mobile phones, which only need stability and performance, so they don’t care about having a closed-source patched kernel, but our users do."
https://medium.com/scaleway-cloud/thank-you-scaleway-9dc5ba30b9a5#.jy9ubokpu
In fact, those 3€ ARM servers are near useless, and slow at best, if you want to develop systems..
Share this post
Link to post
Share on other sites
This is a different story.
Eclipse, RubyMine, JDeveloper, .... a lot of IDEs are working. No Microsoft support, but everything else is working.
Same with Mainline kernel support. 3.14LS seems outdated, but a lot of stuff is backported - even Docker support. So a 3'alike Version can be "newer" than a 4.2 kernel.
Share this post
Link to post
  • Similar Content
    • By wlanboy
      Resin.io is a fork of the Yocto-based OS and is now able to run Docker containers on Linux IoT devices.
      Resin known for their Linux/Javascript-based IoT framework forked their Linux OS behind the framework as an open source project over a year ago. The open source ResinOS is now publicly available on its own: https://github.com/resin-os
      ResinOS can run on mostly ARM-based embedded Linux platforms including the Raspberry Pi, BeagleBone, and Odroid:
      https://resinos.io/
      The open source Linux CoreOS (https://coreos.com/why/), supports only x86-64, although attempts have been made to port it to the Raspberry Pi. There are other Docker-friendly Linux distributions like Red Hat based Project Atomic, but still no ARM support.
      Snappy Ubuntu Core, which supports Docker on ARM and x86 embedded targets, but still on some major brands.
      So ResinOS looks like a great new Linux distribution.
    • By wlanboy
      Allwinner:
      Allwinner A10/A20 – Display engine clocks (TCON, FE, DE), I2S audio interface (ASoC) driver, added NFC node to DTS Allwinner H3 – Clocks (through sunxi-ng), USB multi-reset lines support AXP2xx driver – External drivebus support, AXP223 USB power supply support, AXP809 PMIC support Broadcom BCM53125 support as it’s used in Lamobo / Banana Pi R1 router board. New boards – Polaroid MID2407PXE03 & inet86dz (Allwinner A23 tablets), Banapi M1+, Banapi M2+, Allwinner Parrot (Allwinner R16 EVB) Samsung
      Enable drivers for Exynos7 and Exynos5433 based boards: S2MPS clock driver, SoC: RTC, SPI, watchdog, EHCI, OHCI, DWC3, ADC and PWM, Enable Samsung SoC sound Qualcomm Device Tree Changes:
      Reverse BAM dma node reverts Add BAM remote control options for affected platforms Enable peripherals on APQ8074 dragonboard Enable PMA8084 pwrky Fix PMIC reg entries by removing unnecessary size element Add SCM binding and support for all currently supported boards Add Qualcomm WCNSS binding documentation Rename db600c to SD_600eval and add peripheral nodes Remove gpio key entry from Nexus7 Add APQ8060 based dragonboard and associated peripherals Add ARMv7 PMU for IPQ4019 Other new ARM hardware or SoCs
      NXP i.MX 7Solo, Broadcom BCM23550, Broadcom BCM2837 (Raspberry Pi 3)
      Grapped out of the change log: https://kernelnewbies.org/Linux_4.8
    • By fm7
      http://www.wsj.com/articles/softbank-agrees-to-buy-arm-holdings-for-more-than-32-billion-1468808434
    • By DomainBop
      Scaleway added x86_64 dedicated Avoton's to their cloud mix today.  All offerings are dedicated bare metal servers with unlimited transfer,  LSSD storage (the €23.99 offering also includes 250GB DSSD storage)
      new offerings:
      €11.99month
      Avoton C2550
      4 Dedicated x64 Cores
      8GB Memory
      50GB SSD Disk
      1 Flexible public IPv4
      300Mbit/s Internet bandwidth
      2.5Gbit/s Internal bandwidth
      €17.99month
      Avoton C2750
      8 Dedicated x64 Cores
      16GB Memory
      50GB SSD Disk
      500Mbit/s Internet bandwidth
      €23.99month
      Avoton C2750
      32GB Memory
      50GB SSD Disk
      250GB Direct SSD Disk
      800Mbit/s Internet bandwidth
      blog announcement: https://blog.scaleway.com/2016/03/08/c2-insanely-affordable-x64-servers/
    • By MannDude
      Source: https://apps.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&calledFromFrame=N&application_id=Ti%2FYleaJNSl%2BTR5mL5C0WQ%3D%3D&fcc_id=2ABCB-RPI32 && https://fccid.io/2ABCB-RPI32
      First looks at the RPI3:
      Unsure of the exact operating specs, I'd hope there is some other improvements elsewhere as well but built in wifi and bluetooth will certainly be a nice feature to have. The photos above were pulled from http://www.theregister.co.uk/2016/02/26/raspberry_pi_3/
