• Announcements
    • MannDude
      -MannDude
Sign in to follow this
Followers 0
Munzy
NodeJS Async function help!
2 posts in this topic
Alright, so I am new to nodejs from php. As most know, php being linear/blocking made coding *easy* per-say. However, I have found myself loving nodejs, and I am having a hard time wrapping my mind around how to let a nodejs function run async, but then wait for responses of that async function before continuing.
Here is some example code
var ping = require("ping");
var verHosts = [
'192.168.230.118',
'192.168.230.25'
var verStatus = 0;
verHosts.forEach(function(host) {
        ping.sys.probe(host, function(isAlive){
            if(isAlive == true) {
                verStatus++;
    console.log(Date() + " " + "Verified status is at: " + verStatus);
    if(verStatus > 0) { // continue shiz and giggles here after I get the above};
If you could elaborate as I am trying to learn as well, not just copy paste in dummy mode!
Thanks!
Share this post
Link to post
Share on other sites
Basically, you'd use Promises. Any kind of looping or conditional asynchronous work is very hard to get right with callbacks alone.
I've put together a reading list about Promises here, that should get you started - Promise.map is most likely what you're looking for in particular :)
Share this post
Link to post
Followers 0
