• Announcements
    • MannDude
      -MannDude
CentOS released for ARM devices!
13 posts in this topic
I know CentOS is the OS of choice for many web hosts and I assume some of them use it otherwise day to day.
CentOS has released a new version with ARM support:
Quote
We were only given access to the download links, and based on the name of the binary images, we can tell you that CentOS 7 Linux will now work on various AMv7 devices. However, pre-built binary images are available only for the popular Raspberry Pi 2, Banana Pi, and CubieTruck single-board computers (SBCs).
Source: http://news.softpedia.com/news/centos-7-linux-officially-released-for-raspberry-pi-2-banana-pi-and-cubietruck-497891.shtml
Share this post
Link to post
Share on other sites
now all we need are actual ARM boards that aren't gimmicky cheap SoCs like the pi or cubieboards
for years people have been talking about ARM in the datacenter, ARM-based storage appliances, and we aren't seeing any of it.
it would be cool to build out inexpensive, scale-out storage on ARM someday
1 person likes this
Share this post
Link to post
There are real ARM 64 bit boards out there that are many many core and with real backplanes.  Issue is you are buying a complete solution with such, the CPU, the server chasis, RAM, drives, all of it.   So the units aren't cheap whatsoever.   With that you get odd vendor lockin, not like IBM or HP or Dell or name that big company with network of support and warehoused parts regionally.  Probably not much DIY parts swap either.  So dealing with higher ownership cost than many generic box buyers are use to.
Bundle all that with what has a been a limited software stack, plenty still not available for ARM... and the lower performance so far on sheer wide open testing compared to big iron CPUs.
ARM is taking longer to arrive as a  serious contender in the DC.  Clearly isn't yet the time for it, but, it seems like we are getting closer for a lot of different usage cases.  I welcome it.  Using lowly ARM now all over with limited network and shared bus stuff... Stuff works, just not enterprise-like.
Share this post
Link to post
ARM is a wide range of cpu, soc and system designs.
ARM cores are used in PDAs and smartphones. Microsoft's first generation Surface and Surface 2, Apple's iPads, and Asus's Eee Pad Transformer tablets used ARMs. Others include Apple's iPhones and iPod, Canon PowerShot digital cameras, Nintendo DS handheld game consoles and TomTom navigation systems.
And all embedded and appliance stuff like Pogoplug, NAS, firewalls, netfilters, Voip gateways,...
1 person likes this
Share this post
Link to post
I've been using Scaleway.com ARM servers for a while and they work pretty well.  You can't buy the hardware though.  And ARM storage appliances definitely do exist.  But ARM stuff currently competes only against the low end of x86 stuff.  At the high end, there's Power8, but it hasn't gotten that much traction.  I don't see what's so great about ARM anyway though.  It's a product, it fills a need, fine.  But ARM Holdings is not exactly a knight in shining armor saving us from the evil behemoth Intel.  AMD is sort of that, though shaky these days.  All the current ARM application processors have instruction sets you can only find out through an NDA, plus the on-chip GPU's (Mali etc) are also non-public.  With Intel stuff, at least the manuals are all online and public.
Share this post
Link to post
Low power consumption, able to run at higher ambient heat than most standard chips, can be used in industrial use cases (you can actually order industrial versions which can sustain quite a vast range of operating temperatures)which means lower cooling costs and all adds up to lower cost of operation per core/server.  The reason scaleway can provide them at the cost they do is because of the density and the relatively low power consumption.  If you go and readthere are 18 C1s per blade * 16 blades per rack mountable unit * 3 units per rack => 864 C1s/rack. (though they speculate up to 1000?).   So  it is much less expensive to run than standard blade servers running Intel or AMD gear, per core and power costs.
 "Even if the actual density of C1 servers is 50% less than you'd achieve with a virtualised setup, the bang per buck will be far greater."
Cheers!
Share this post
Link to post
Definitely @TheLinuxBug the power envelope adds up.  Question is if they can plumb the rest of it to deal with the mass traffic / packets / etc.
Didn't Scaleway have multiple layer problems with their solution?  I saw their network appeared to perform very slowly.   Unclear if contention in the racks and switches or out to the net.  Considering they were doing disk across network, could be both.  Then again, maybe they racked dual network and split things to own switching fabrics.
I love their model and impossible not to like the pricing.   Just need more inventory and to take PayPal :)
This model of lowly ARM and MIPs boards as parallel processors in a 'cluster' has been done many times over in labs at Universities.  It was viable and competitive / even outperformed Intel per watt the better part of a decade ago.
Unsure if 2016 is going to be the year of ARM in the datacenter, but it's happening soon.  I keep pointing to the maturing software stack.  Once that stack fleshes out a bit more, yeah, I think it will be like the impact of ARM with tablets and phones and what it did to Intel/AMD on the desktop and eroded sales for them.
Share this post
Link to post
OVH decided not to offer Power8 cloud service after testing it on RunAbove.  Online.net is offering a Power8 dedicated for €1,599 /month (plus €1,500 setup https://www.online.net/en/dedicated-server/dedibox-power8 ) and they announced plans for a Power8 cloud offering in September ( http://www-03.ibm.com/press/us/en/pressrelease/47681.wss )
Quote
This year was the year we began to see it in European datacenters and in the corporate sector.  The Scaleway (Online.net) cloud, Hetzner with a range of ARM servers, RunAbove (OVH) testing a 64-bit ARM cloud.  PayPal also announced it was deploying ARM servers earlier this year ( http://www.datacenterknowledge.com/archives/2015/04/29/paypal-deploys-arm-servers-in-data-centers/ )
2 people like this
Share this post
Link to post
As per my knowledge ARM cores are used in PDAs and smartphones. Microsoft's first generation Surface and Surface 2, Apple's iPads, and Asus's Eee Pad Transformer tablets used ARMs. Others include Apple's iPhones and iPod, Canon PowerShot digital cameras, Nintendo DS handheld game consoles and TomTom navigation systems.
Share this post
Link to post
Over 3 months apart.... :)
Edited by raj
highlighted text
Share this post
Link to post
  • Similar Content
    • By wlanboy
      Resin.io is a fork of the Yocto-based OS and is now able to run Docker containers on Linux IoT devices.
      Resin known for their Linux/Javascript-based IoT framework forked their Linux OS behind the framework as an open source project over a year ago. The open source ResinOS is now publicly available on its own: https://github.com/resin-os
      ResinOS can run on mostly ARM-based embedded Linux platforms including the Raspberry Pi, BeagleBone, and Odroid:
      https://resinos.io/
      The open source Linux CoreOS (https://coreos.com/why/), supports only x86-64, although attempts have been made to port it to the Raspberry Pi. There are other Docker-friendly Linux distributions like Red Hat based Project Atomic, but still no ARM support.
      Snappy Ubuntu Core, which supports Docker on ARM and x86 embedded targets, but still on some major brands.
      So ResinOS looks like a great new Linux distribution.
    • By Lonesome.Zombie
      i have in stalled wordpress on centos 6.5 (64bit) and when i change permalink settings and click on any post it shows me an error page, i have updated .htaccess file and curl is enabled on my vps but still cant igure out what is the actual problem. its a fresh installation please someone help me to solve this issue.
    • By wlanboy
      Allwinner:
      Allwinner A10/A20 – Display engine clocks (TCON, FE, DE), I2S audio interface (ASoC) driver, added NFC node to DTS Allwinner H3 – Clocks (through sunxi-ng), USB multi-reset lines support AXP2xx driver – External drivebus support, AXP223 USB power supply support, AXP809 PMIC support Broadcom BCM53125 support as it’s used in Lamobo / Banana Pi R1 router board. New boards – Polaroid MID2407PXE03 & inet86dz (Allwinner A23 tablets), Banapi M1+, Banapi M2+, Allwinner Parrot (Allwinner R16 EVB) Samsung
      Enable drivers for Exynos7 and Exynos5433 based boards: S2MPS clock driver, SoC: RTC, SPI, watchdog, EHCI, OHCI, DWC3, ADC and PWM, Enable Samsung SoC sound Qualcomm Device Tree Changes:
      Reverse BAM dma node reverts Add BAM remote control options for affected platforms Enable peripherals on APQ8074 dragonboard Enable PMA8084 pwrky Fix PMIC reg entries by removing unnecessary size element Add SCM binding and support for all currently supported boards Add Qualcomm WCNSS binding documentation Rename db600c to SD_600eval and add peripheral nodes Remove gpio key entry from Nexus7 Add APQ8060 based dragonboard and associated peripherals Add ARMv7 PMU for IPQ4019 Other new ARM hardware or SoCs
      NXP i.MX 7Solo, Broadcom BCM23550, Broadcom BCM2837 (Raspberry Pi 3)
      Grapped out of the change log: https://kernelnewbies.org/Linux_4.8
    • By Big Boss
      hello vpsboard can you help me about my problem regarding my VPS ? I have a 1gb ram KVM VPS and the OS I have installed is a centOS 6.5 32bit  .
      I want to access my VPS and browse internet using it what things do I need to install to have a desktop view on my VPS ?
    • By fm7
      http://www.wsj.com/articles/softbank-agrees-to-buy-arm-holdings-for-more-than-32-billion-1468808434
