• Announcements
    • MannDude
      -MannDude
ARM device with decent disk performance?
34 posts in this topic
Here is my speed test on a new Octa Core ARM box.  It has 32GB of disk built into the unit + has USB 3.0 + SATA...
[email protected]:/home/linaro# hdparm -tT --direct /dev/mmcblk0
/dev/mmcblk0:
 Timing O_DIRECT cached reads:    68 MB in  2.05 seconds =  33.13 MB/sec
 Timing O_DIRECT disk reads:  98 MB in  3.03 seconds =  32.37 MB/sec
[email protected]:/home/linaro# dd if=/dev/zero of=test bs=16k count=8k conv=fdatasync && rm -rf test
8192+0 records in
8192+0 records out
134217728 bytes (134 MB) copied, 4.16864 s, 32.2 MB/s
Not bad.  From the looks of it, the config as-is isn't too optimal either... probably can get more out of this.
Link for this device: http://www.rikomagic.com/en/product/showpro_id_70_pid_22.html
Share this post
Link to post
Share on other sites
Wow, that looks like a nice box if a little bit power hungry.   Could you run:
  • openssl speed rsa1024 (scaleway: 196.4 sign, 3465.5 verify)
  • time echo "scale = 1000; 4*a(1)" | bc -l  (scaleway: 1.78 sec)
  • time echo "scale = 2000; 4*a(1)" | bc -l (scaleway: 10.28 sec)
Might ask for a few other tests involving downloads, if you're up for that.  You might have to apt-get install bc for the bc tests.
Can I ask where you bought the box, and what it cost?
Thanks!
Share this post
Link to post
A20-OLinuXino-LIME:
Doing 1024 bit private rsa's for 10s: 1617 1024 bit private RSA's in 9.98s
Doing 1024 bit public rsa's for 10s: 29040 1024 bit public RSA's in 9.98s
OpenSSL 1.0.1e 11 Feb 2013
built on: Thu Dec  3 18:30:13 UTC 2015
options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr)
compiler: gcc -fPIC -DOPENSSL_PIC -DZLIB -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM
                  sign    verify    sign/s verify/s
rsa 1024 bits 0.006172s 0.000344s    162.0   2909.8
3.141592653589793238462643383279502884197169399375105820974944592307\
81640628620899862803482534211706798214808651328230664709384460955058\
22317253594081284811174502841027019385211055596446229489549303819644\
28810975665933446128475648233786783165271201909145648566923460348610\
45432664821339360726024914127372458700660631558817488152092096282925\
40917153643678925903600113305305488204665213841469519415116094330572\
70365759591953092186117381932611793105118548074462379962749567351885\
75272489122793818301194912983367336244065664308602139494639522473719\
07021798609437027705392171762931767523846748184676694051320005681271\
45263560827785771342757789609173637178721468440901224953430146549585\
37105079227968925892354201995611212902196086403441815981362977477130\
99605187072113499999983729780499510597317328160963185950244594553469\
08302642522308253344685035261931188171010003137838752886587533208381\
42061717766914730359825349042875546873115956286388235378759375195778\
18577805321712268066130019278766111959092164201988
real    0m2.455s
user    0m2.420s
sys     0m0.010s
18577805321712268066130019278766111959092164201989380952572010654858\
63278865936153381827968230301952035301852968995773622599413891249721\
77528347913151557485724245415069595082953311686172785588907509838175\
46374649393192550604009277016711390098488240128583616035637076601047\
10181942955596198946767837449448255379774726847104047534646208046684\
25906949129331367702898915210475216205696602405803815019351125338243\
00355876402474964732639141992726042699227967823547816360093417216412\
19924586315030286182974555706749838505494588586926995690927210797509\
30295532116534498720275596023648066549911988183479775356636980742654\
25278625518184175746728909777727938000816470600161452491921732172147\
72350141441973568548161361157352552133475741849468438523323907394143\
33454776241686251898356948556209921922218427255025425688767179049460\
16534668049886272327917860857843838279679766814541009538837863609506\
80064225125205117392984896084128488626945604241965285022210661186306\
74427862203919494504712371378696095636437191728746776465757396241389\
086583264599581339047802759008
real    0m14.080s
user    0m14.040s
sys     0m0.010s
Can't believe that Scaleway is that slow.
1 person likes this
Share this post
Link to post
Thanks!
This box like many of these specs out nice on paper but fails to deliver in Linux as shipped by default.  Sure the upfront base disk speeds looked good. That's where it ends for real world though.
Each board seems to have it's own little special oddness.  Ditto for the CPUs on ones like this.
Although they call this an Octa Core it is and isn't.   It has 4 cores of one type at a higher MHz level and then 4 cores of some other type at a lower MHz level.  Haven't looked at or found CPU sheet to demystify it yet.   Linux shows 8 cores, but I fail to see them utilized yet.  I've seen 2 cores utilized with things I run to see if my stack will work find on the device. The cores work when I tested openssl not linear increase near proportional to the cores, but like I said I don't think they all clock in at the same.
While my stack runs on this device, the performance sucks and is wrong direction with default base install.  That said running OpenJDK + MySQL + scripts.  Page generation times on this device are basically 300ms.  Raspberry Pi quad core does 100ms on average faster.  Being outpaced by a Pi?  Meh.
I am blaming Linaro as being poured in, but not optimized at all for this.  That's what it shipped with, so I need to find support / hobbyists out there and figure out what OS works better / or optimizations.
Let's run your tests on my Odroid U2 to compare with Scaleway.  The U2 is old, the original Odroid model I do believe, still capable :)
    odroid u2: 326.7 sign, 5844.5 verify
    odroid u2: 1.152 sec
    odroid u2: 6.479 sec
So on those, the Odroid U2 trounces the Scaleway.
    (Rikomagic MK80LE: 442.5 sign, 7789.3 verfiy)
    (odroid u2: 326.7 sign, 5844.5 verify)
    (Rikomagic MK80LE: .998 sec)
    (odroid u2: 1.152 sec)
    (Rikomagic MK80LE: 5.489 sec)
    (odroid u2: 6.479 sec)
So the Rikomagic MK80LE beats out the Odroid on these and Scaleway runs last.
Now let's run this with the Raspberry Pi quad core with default board settings:
    (Rapberry Pi Quad Core: 147 sign 2645.5 verify)
    (Rapberry Pi Quad Core: 2.201 sec)
    (Rikomagic MK80LE .998 sec)
    (Rapberry Pi Quad Core: 12.518 sec)
    (Rikomagic MK80LE 5.489 sec)
Based on these, the Raspberry Pi Quad Core is the slowest.
Since openssl supports multi core, lets run 4 cores on the Pi vs. the Rikomagic vs. Odroid U2
  • openssl speed rsa1024 -multi 4
    (Rapberry Pi Quad Core: 580.6 sign 10485.3 verify)
    (Rikomagic MK80LE: 1707.4 sign 29144.2 verify )
    (odroid u2: 1295.1 sign 23359.8 verify)
    Now since the Riko has 8 cores, we run multi 8 test
  • openssl speed rsa1024 -multi 8
    (Rikomagic MK80LE: 2467.6 sign 42483.2 verify )
Share this post
Link to post
I'd be wary of the Rikomagic devices.  Not the best track record of shipping software stack that utilizes the hardware.
Tronsmart has a similar device if you are interested in USB 3, SATA, larger RAM, etc.
Tronsmart Draco AW80 is the model you want to check out.
Ubuntu in one review for that model wasn't exactly entirely ready, but it appears to be ahead of the Rikomagic at this point compared to box I have.
Tronsmart is hit or miss.  Upside is their devices are easier to find the States and better prices.  I have a dual core settop box from them that I need to get back to using.  Decent device for Android.
Share this post
Link to post
Figure I'd try the Ubuntu  installed on this Rikomagic.
YouTube HD just won't work.. horrendously overloaded.  Turn it down to 480 and it works, but cores all going freaking busy crazy.  So the video card and acceleration clearly aren't working as shipped.  CPU bound video.  MEH!
Searching for new software / fresh OS install howto.. ideally this is just old shipped stack.
Share this post
Link to post
It it called big.LITTLE Technology
Quote
big.LITTLE Processing – How does it work?
The high performance and high efficiency CPU clusters are connected through a cache coherent interconnect fabric such as the ARM CoreLink™ CCI-400.This hardware coherency enables the same view of the memory to both the big and LITTLE CPU clusters. The processors look like one multicore CPU to the operating system (OS). User space software on a big.LITTLE SoC is identical to the software that would run on a standard Symmetrical Multi-Processing (SMP) CPU.
How does the work get scheduled to the right processor?
Global Task Scheduling (GTS) gives the OS awareness of the big and LITTLE processors, and the ability to schedule individual threads of execution on the appropriate CPU core based on dynamic run-time behavior. ARM has developed a kernel space patch set based on GTS called big.LITTLE MP that keeps track of load history as each thread runs, and uses the history to anticipate the performance needs of the thread next time it runs. This software is in operation on the use case graph above (Fig. 1) and in the measured results below (Fig. 2), where big.LITTLE technology is delivering energy savings as high as 75% for the same or higher delivered performance.
Cheers!
1 person likes this
Share this post
Link to post
I am developing a crush on Orange Pi.  They have a 2GB of RAM version that might cover all my RAM needs .. and has SATA.
Check this out:
http://www.orangepi.org/downloadresources/
This folks is what support site should look like for these ARM boards.  Everything tidy in one spot.  Downloads to the current distro files.
Share this post
Link to post
Binary non-open super-closed packed with old kernel video drivers... welcome to the Allwinner SoC world. Hopefully some kernel hackers do buy your stuff...
My OlinuXino does have video drivers as binary package. FullHD working like a charm.
1 person likes this
Share this post
Link to post
Check this out:
I want to be excited for you, but the people doing the real work to get these boards mainstream is http://linux-sunxi.org They are the ones who are working to get it so you can run something other than the old 3.x linux versions with an old outdated kernel.  If you want to know where to find the best information about your Allwinner SoC linux-sunxi is the answer, both their webpage and IRC channel can be quite useful.  A lot of people give their time freely to help create and reverse engineer drivers which Allwinner will not.
Not saying they don't provide some good material for their board, but you will find most of the advancements being had for the H3 are being done by the linux-sunxi team.
my 2 cents.
Cheers!
1 person likes this
Share this post
Link to post
my 2 cents.
Cheers!
Allwinner is clearly a PITA.  Quite a shame because they have capable gear.  Strange approach they are taking to not support their hardware for Linux and closed / lacking drivers.
The Sunxi site is a great reference.  Much appreciated on that.
Share this post
Link to post
I actually found the Rikomagic as an open box / used thing.  Paid very little for it relative to the upwards of $145-200 they seem to be asking for them currently.
I'll only buy ARM at $0 to $80.  Nothing shipping at this time to justify more unless they include a display or something original.
Share this post
Link to post
12 hours ago, wlanboy said:
Anyone have a CuBox-i running?
Looks like a decent box: http://solid-run.com/freescale-imx6-family/cubox-i/cubox-i-specifications/
Definitely an interesting device.   I've stayed away from that brand due to high price point relatively speaking and the OS option front side is OpenElec and Android.  Unsure if these have more community support out there.
I know the Gigabit on these is half speed / not up to spec due to shared or limited bus.  Tired of that limitation all over town...
Armbian has support for this board:
http://www.armbian.com/cubox-i/
Share this post
Link to post
  • Similar Content
    • By wlanboy
      Resin.io is a fork of the Yocto-based OS and is now able to run Docker containers on Linux IoT devices.
      Resin known for their Linux/Javascript-based IoT framework forked their Linux OS behind the framework as an open source project over a year ago. The open source ResinOS is now publicly available on its own: https://github.com/resin-os
      ResinOS can run on mostly ARM-based embedded Linux platforms including the Raspberry Pi, BeagleBone, and Odroid:
      https://resinos.io/
      The open source Linux CoreOS (https://coreos.com/why/), supports only x86-64, although attempts have been made to port it to the Raspberry Pi. There are other Docker-friendly Linux distributions like Red Hat based Project Atomic, but still no ARM support.
      Snappy Ubuntu Core, which supports Docker on ARM and x86 embedded targets, but still on some major brands.
      So ResinOS looks like a great new Linux distribution.
    • By wlanboy
      Allwinner:
      Allwinner A10/A20 – Display engine clocks (TCON, FE, DE), I2S audio interface (ASoC) driver, added NFC node to DTS Allwinner H3 – Clocks (through sunxi-ng), USB multi-reset lines support AXP2xx driver – External drivebus support, AXP223 USB power supply support, AXP809 PMIC support Broadcom BCM53125 support as it’s used in Lamobo / Banana Pi R1 router board. New boards – Polaroid MID2407PXE03 & inet86dz (Allwinner A23 tablets), Banapi M1+, Banapi M2+, Allwinner Parrot (Allwinner R16 EVB) Samsung
      Enable drivers for Exynos7 and Exynos5433 based boards: S2MPS clock driver, SoC: RTC, SPI, watchdog, EHCI, OHCI, DWC3, ADC and PWM, Enable Samsung SoC sound Qualcomm Device Tree Changes:
      Reverse BAM dma node reverts Add BAM remote control options for affected platforms Enable peripherals on APQ8074 dragonboard Enable PMA8084 pwrky Fix PMIC reg entries by removing unnecessary size element Add SCM binding and support for all currently supported boards Add Qualcomm WCNSS binding documentation Rename db600c to SD_600eval and add peripheral nodes Remove gpio key entry from Nexus7 Add APQ8060 based dragonboard and associated peripherals Add ARMv7 PMU for IPQ4019 Other new ARM hardware or SoCs
      NXP i.MX 7Solo, Broadcom BCM23550, Broadcom BCM2837 (Raspberry Pi 3)
      Grapped out of the change log: https://kernelnewbies.org/Linux_4.8
    • By fm7
      http://www.wsj.com/articles/softbank-agrees-to-buy-arm-holdings-for-more-than-32-billion-1468808434
    • By DomainBop
      Scaleway added x86_64 dedicated Avoton's to their cloud mix today.  All offerings are dedicated bare metal servers with unlimited transfer,  LSSD storage (the €23.99 offering also includes 250GB DSSD storage)
      new offerings:
      €11.99month
      Avoton C2550
      4 Dedicated x64 Cores
      8GB Memory
      50GB SSD Disk
      1 Flexible public IPv4
      300Mbit/s Internet bandwidth
      2.5Gbit/s Internal bandwidth
      €17.99month
      Avoton C2750
      8 Dedicated x64 Cores
      16GB Memory
      50GB SSD Disk
      500Mbit/s Internet bandwidth
      €23.99month
      Avoton C2750
      32GB Memory
      50GB SSD Disk
      250GB Direct SSD Disk
      800Mbit/s Internet bandwidth
      blog announcement: https://blog.scaleway.com/2016/03/08/c2-insanely-affordable-x64-servers/
    • By MannDude
      Source: https://apps.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&calledFromFrame=N&application_id=Ti%2FYleaJNSl%2BTR5mL5C0WQ%3D%3D&fcc_id=2ABCB-RPI32 && https://fccid.io/2ABCB-RPI32
      First looks at the RPI3:
      Unsure of the exact operating specs, I'd hope there is some other improvements elsewhere as well but built in wifi and bluetooth will certainly be a nice feature to have. The photos above were pulled from http://www.theregister.co.uk/2016/02/26/raspberry_pi_3/
