• Announcements
    • MannDude
      -MannDude
Build simple web interface for redis key/value store
2 posts in this topic
This is my second post for php based projects. My first thread is about an IoT plattform for Ardunio clients.
This post is about creating a simple web interface for a redis key/value store. If you want to install your own redis database you can use this tutorial:
I will use following php frameworks to get the rest interface done: Slim, CorSlim, Predis.
All the server and client code will be available at github: https://github.com/wlanboy/php-redis-rest-service
a) Server
We first have to enable CORS support to enable clients of other domains to use our service:
require ('CorsSlim/CorsSlim.php');
$app->add(new \CorsSlim\CorsSlim());
$corsOptions = array(
    "origin" => "*",
    "exposeHeaders" => array("Content-Type", "X-Requested-With", "X-authentication", "X-client"),
    "allowMethods" => array('GET', 'POST', 'PUT', 'DELETE', 'OPTIONS')
$cors = new \CorsSlim\CorsSlim($corsOptions);
$app->add($cors);
After that we have to get a connection to our local redis instance:
$app->container->singleton('redisclient', function() {
	$client = new Predis\Client('tcp://127.0.0.1:6379');
    return $client;
And define the routes:
//Redis routes
$app->get('/key/:id', 'getKey');
$app->post('/key', 'addKey');
And implement them with the help of the Predis framework:
function getKey($id) {
	$app = \Slim\Slim::getInstance();
	$client = $app->redisclient;
    try {
	$value = $client->get($id);
	$temp = (object) [
		$id => $value
    	echo json_encode($temp);
    } catch(PDOException $e) {
        echo '{"error":{"text":'. $e->getMessage() .'}}';
Done :-)
b) Client
I use a simple Ajax JS script for the client. The most simple way to create the GET and POST requests.
We first defien a data object which is able to create JSON output:
function KeyValue(key, value) {
	var kv = {"key":key, "value":value};
    kv.toJsonString = function () { return JSON.stringify(kv); };
	return kv;
And a simple send method that reads form data, sends it to the rest service and prints the response:
function sendMessage() {
var key = document.getElementById("postkey").value;
var value = document.getElementById("postvalue").value;
	if (value == "") {
		jQuery.ajax({
			type: "GET",
			url: "https://rest-api/key/"+key,
			contentType: "application/json; charset=utf-8",
			dataType:"json",
				 success: function (data, status, jqXHR) {
					 output = document.getElementById("output");
					 output.innerHTML = JSON.stringify(data);
					 document.getElementById("postkey").focus();
				 error: function (jqXHR, status) {
					 output.innerHTML = status;
Using GetElementByID + value to get the input.
Creating a jQuery ajax request and add the key to the url to get the variable stored in redis.
Same with the POST request to store the value of a variable in redis:
else{
		var contact = KeyValue(key,value);
		jQuery.ajax({
			type: "POST",
			url: "https://rest-api/key",
			data: contact.toJsonString(),
			dataType:"json",
					 output.innerHTML += "<br/>";
					 output.innerHTML += jqXHR.responseJSON;
This time with a data line to get the JSON data of the contact element.
Same JSON.stringify to get the string representation of the json object.
Done.
Simple server & client example to use a redis database without any binary client. Simple HTTP requests to use the redis service.
I will add additional methods to the rest service to add the other redis commands too.
Share this post
Link to post
Share on other sites
  • Similar Content
    • By poomrokc
      Hello , sorry for the confusing title ,I do not speak english as my first language.(and also sorry if the topic does not fit here)
      Problem background: I just want to create a website as a competitive program grader for my school. Like complie and run source code on the server. So below is my idea and i would like some help/suggestions before i do it,I still don't know if this will work.
      Mysql usage:
      The problem one is that i would use one of the table as my user-submission queue.When user submit a code, I first put it in this table(i suppose it put the new row in the bottom of the table?) .
      Python program usage:
      I would run a 24/7 program on my server that check every 10 second  if the queue table is not empty, just run the grading process(I know how to do it) and then pop it off the queue.Then check again.
      PHP usage:
      When a person submit code, i will use php to put it on the queue table,but it may be the same time my python program is popping something off the queue table too. This is where I get confuse whether it will work or not.(Other usage of the php is just things about web interface which I had done before and know what to do)
      So,would this idea even work? Will it break my server or something?As a competitive programmer guy I don't know much snd will greatly appreciate any help from u guys. :)
      Thank you very much.
    • By drmike
      I am looking for a programmer / scripter already familiar with PHP and WHMCS.
      Project type work, one off  custom scripts.  Freelance work for someone out there, per piece.
      If interested, PM me your CV / resume or in lieu of such tell me about your experience.  Informal is fine, alternative learners encouraged.
    • By mainline.realty
      Hello,
      I am new here and I am hoping to get some answers and continue to use this forum for all my VPS issues; I have notices an odd behavior through my site over time and I think it's about time I took care of it; I have a VPS through WHM cPanel. Medium size package with 2 CPU Cores and 4GB RAM. About 300 Posts (WordPress Platform); I am using an Ok theme that is optimized actually and my score through gtmetrix is about 98% - 92% for yslow.
      Here is my issue:
      When I log in to my personal twitter and retweet my website tweets (Let's say about 10 of them) my VPS overloads immediately to 80% or more while it is under 1% any other times. Checking the logs through cPanel I noticed 1 (one) PHP file with "a lot" of queries and that is a sharrre.php - The only thing I can think of is maybe it is not optimized? The theme builder guy is a "no go" for this specific issue. I am attaching the code of that specific file so maybe you guys can help. I would REALLY appreciate it.
      Sarah.
      <?php header('content-type: application/json'); //Sharrre by Julien Hany $json = array('url'=>'','count'=>0); $json['url'] = $_GET['url']; $url = isset(urlencode($_GET['url'])) ? $_GET['url'] ? ''; $type = isset(urlencode($_GET['type'])) ? $_GET['type'] ? ''; $ori_url = isset($_GET['url']) ? $_GET['url'] ? ''; if(filter_var($ori_url, FILTER_VALIDATE_URL)){ if($type == 'googlePlus'){ //source http://www.helmutgranda.com/2011/11/01/get-a-url-google-count-via-php/ $contents = parse('https://plusone.google.com/u/0/_/+1/fastbutton?url=' . $url . '&count=true'); preg_match( '/window\.__SSR = {c: ([\d]+)/', $contents, $matches ); if(isset($matches[0])){ $json['count'] = (int)str_replace('window.__SSR = {c: ', '', $matches[0]); } } else if($type == 'stumbleupon'){ $content = parse("http://www.stumbleupon.com/services/1.01/badge.getinfo?url=$url"); $result = json_decode($content); if (isset($result->result->views)) { $json['count'] = $result->result->views; } } } echo str_replace('\\/','/',json_encode($json)); function parse($encUrl){ $options = array( CURLOPT_RETURNTRANSFER => true, // return web page CURLOPT_HEADER => false, // don't return headers CURLOPT_FOLLOWLOCATION => true, // follow redirects CURLOPT_ENCODING => "", // handle all encodings CURLOPT_USERAGENT => 'sharrre', // who am i CURLOPT_AUTOREFERER => true, // set referer on redirect CURLOPT_CONNECTTIMEOUT => 5, // timeout on connect CURLOPT_TIMEOUT => 10, // timeout on response CURLOPT_MAXREDIRS => 3, // stop after 10 redirects CURLOPT_SSL_VERIFYHOST => 0, CURLOPT_SSL_VERIFYPEER => false, ); $ch = curl_init(); $options[CURLOPT_URL] = $encUrl; curl_setopt_array($ch, $options); $content = curl_exec($ch); $err = curl_errno($ch); $errmsg = curl_error($ch); curl_close($ch); if ($errmsg != '' || $err != '') { /*print_r($errmsg); print_r($errmsg);*/ } return $content; }
    • By wlanboy
      This will be the start of a series of tutorials about IoT, servers, clients and how things can be connected.
      I want to show how a opensource based IoT plattform that is host-able on any shared-hosting account can be build. So no special services, no Azure, no Google, no Bling-Bling-Newish things.
      No Ruby, no Java, no Phyton. Plain PHP on server and C on client side. No root permissions and no customizing. Back to the roots of simple webhosting.
      Every single line of code will be published on GitHub. Advices and pushes are welcome.
      Later on I will add Redis and JS for some Pub/Sub things - but the start will be a plain simple LAMP stack.
      Table of content:
      Motivation Client side Server side Protocols So let's start with 1)
      I really like Ruby - same with MongoDB, Redis, RabbitMQ and Hazelcast. But you have to configure and maintain the whole infrastructure for each single project.
      Quite time consuming and sometimes frustrating if interfaces are changing or new config-files are invented. As fast as these frameworks and services are growing the more deprecated flags are spread through the users.
      Not talking about failover, backup/restore and all the small things rising if more than 10 people are using a plattform.
      A quad-core Raspberry Pi 2 running Ruby code, using a Phyton client connected with a RabbitMQ cluster to store information in a sharded MongoDB database. Whoohoo sounds good must be good. My math professor told me one thing that fits on such projects: "If you do not have a simple solution you are only fixing symptoms and not the real problem". He was and is right.
      So the IoT thing is about reading analog/digital signals and storing them into a database. Exluding commands, workflows, visualization and all the other BI stuff.
      I used the Raspberry Pi for most stuff because it was easy to run Ruby/Phyton scripts doing the whole work. But if you look to what has to be done there are three simple steps: measure, ship and store.
      Measure signals is simple with any AVR 8-bit microcontroller. But they are lacking one thing: The internet connection.
      The electronic things are quite easy and a physical LAN connection is easy but the TCP-IP stack is very expensive for microcontrollers - they have 2kb of RAM. Good luck to handle SSL handshakes.
      But why should a single chip do all the work? The make-all-things-possible SoCs are quite expensive and you can only touch them through an SDK. No direct access to the core. So back to the basics.
      What do you need to "ship" the data? Not much if you have an OpenWRT device. Curl is your friend. Just post the information and done. Authentification, SSL, encoding is done within this tool and you only need a bash and a working internet connection.
      Most routers do not have a serial connection so I found an cheap way to connect the Arduino and the OpenWRT world.
      You will find a quite simple solution on the server side too - if you look what has to be done - just receive a post request and store it into a database. Something, I strongly believe, that can be done without Java and Phyton.
      We will of course build a REST-API, a documentation, authentification, tokens, SSL. So not a too simple PHP script - remeber we want to host the stuff on a shared hosting account for some $ per year.
      2)
      We start with a cheap Arduino Uno R3 and a 9V 1330mA power adapter.
      ATmega328P with 32 KB flash memory, 2 KB SRAM running with 16 MHz.
      You have to set a jumper (old IDE HDD jumper is just fine) to disable the Mega16u2 chip.
      Background: The Mega16u2 is used to upload the code from USB to the ATmega328P chip. But this connection is used for the bridge framework between OpenWRT and the Arduino.
      The Arduino cost about $20.
      There is a Arduino version with an OpenWRT core but it is quite expensive: Arduino YÚN costs about $80.
      The Dragino Yun Shield which can be stacked on any Arduino costs $29. The core itself is opensource - in contrast to the closed YUN product.
      Product page: http://www.dragino.com/products/yunshield/item/98-yun-shield-v2-3.html
      Wiki page: http://wiki.dragino.com/index.php?title=Yun_Shield
      Hardware specs:
      Processor: 400MHz Flash: 16MBytes RAM: 64MBytes 1 x 10M/100M RJ45 connector 150M WiFi 802.11 b/g/n External Antenna via I-Pex connector 1 x USB 2.0 host connector, used for USB storage or 3G connection 1 x MicroSD card slot Compatible with 3.3v or 5v Arduino A lot of power to run a http client. Compatible with all 3.3v and 5v boards!
      Running the Arduino Bridge library: https://www.arduino.cc/en/Reference/YunBridgeLibrary
      Within the AVR code you are able to call functions on the Linux core of the shield. Some basic commands are wrapped like curl:
      void sendDataToServer(String data) { Serial.println("http client begin"); HttpClient client; String url = "http://testing.com/arduino?data="+data; Serial.println(url); client.get(url); while (client.available()) { char c = client.read(); Serial.print(c); } Serial.println("http client end"); } And the same with process:
      void postData() { Process linuxcommand; String curlCmd; String curlData[NUM_FIELDS]; // Construct curl data fields for (int i=0; i<NUM_FIELDS; i ) { curlData[i] = "--data \"" fieldName[i] "=" fieldData[i] "\" "; } // Construct the curl command: curlCmd = "curl "; curlCmd = "--header "; curlCmd = "\"Key: "; curlCmd = privateKey; curlCmd = "\" "; for (int i=0; i<NUM_FIELDS; i ) curlCmd = curlData[i]; curlCmd = serviceURL publicKey; Serial.print("Sending command: "); Serial.println(curlCmd); linuxcommand.runShellCommand(curlCmd); Serial.print("Response: "); while (linuxcommand.available()) { char c = linuxcommand.read(); Serial.write(c); } } This code is running on the 8-bit AVR microcontroller which is communicating with the OpenWRT Linux system through the bridge.
      So a 5V * 1A = 0.12 kW per day device - able to use 5V logic and any WLAN connection - costing sub $50 - which is able to call any REST-Api with a simple C code. No Ruby, Phyton, Node.js or Java needed.
      End of first part. Looking forward for any comments.
