httpoxy A CGI application vulnerability for PHP, Go, Python and others
httpoxy is a set of vulnerabilities that affect application code running in CGI, or CGI-like environments. It comes down to a simple namespace conflict:
  • RFC 3875 (CGI) puts the HTTP Proxy header from a request into the environment variables as HTTP_PROXY
  • HTTP_PROXY is a popular environment variable used to configure an outgoing proxy
This leads to a remotely exploitable vulnerability. If you’re running PHP or CGI, you should block the Proxy header now. Here’s how.
httpoxy is a vulnerability for server-side web applications. If you’re not deploying code, you don’t need to worry.
What can happen if my web application is vulnerable?
If a vulnerable HTTP client makes an outgoing HTTP connection, while running in a server-side CGI application, an attacker may be able to:
  • Proxy the outgoing HTTP requests made by the web application
  • Direct the server to open outgoing connections to an address and port of their choosing
  • Tie up server resources by forcing the vulnerable software to use a malicious proxy
httpoxy is extremely easy to exploit in basic form.
See here: https://httpoxy.org/
The assigned CVEs so far:
  • CVE-2016-5385: PHP
  • CVE-2016-5386: Go
  • CVE-2016-5387: Apache HTTP Server
  • CVE-2016-5388: Apache Tomcat
  • CVE-2016-1000109: HHVM
  • CVE-2016-1000110: Python
CloudFlare sites protected from httpoxy: https://blog.cloudflare.com/cloudflare-sites-protected-from-httpoxy/
quick fixes:
Nginx debian/ubuntu/CentOS etc
echo 'fastcgi_param HTTP_PROXY "";' >> /etc/nginx/fastcgi_params
Nginx FreeBSD
echo 'fastcgi_param HTTP_PROXY "";' >> /usr/local/etc/nginx/fastcgi_params
Apache2 CentOS
echo "RequestHeader unset Proxy early" >> /etc/httpd/conf/httpd.conf
Apache2 Debian Jessie and Ubuntu
a2enmod headers
create file
nano /etc/apache2/conf-available/httpoxy.conf
paste and save:
<IfModule mod_headers.c>
</IfModule>
a2enconf httpoxy
final step: restart Nginx and Apache
edited to add: I spent part of Thursday afternoon applying patches...
lighttpd:
nano /etc/lighttpd/deny-proxy.lua
content:
if (lighty.request["Proxy"] == nil) then return 0 else return 403 end
nano /etc/lighttpd/lighttpd.conf
content:
server.modules += ( "mod_magnet" )
magnet.attract-raw-url-to = ( "/etc/lighttpd/deny-proxy.lua" )
graeme
Python web apps are highly unlikely to be affected. The linked page says "Python code must be deployed under CGI to be vulnerable", and Python CGI scripts are a rarity. In addition to that you need to use a library that uses the HTTP_PROXY environment variable.
