Awhile back, I did a review for A Small Orange's Shared hosting. I took the chance simply because
1. It was free(they give you $5 off the first month with a coupon and the plan I chose it was free)
2. I was curious about EIG host and if they were all bad.
Certain people on WHT and other places will have you believe that all EIG hosts are bad, awful, no good hosts that you should avoid. That may be true for some or even most, but I implore consumers to do their own legwork and do the research. Get on twitter like I did. Twitter is far more convenient than WHT for finding reviews because customers take to the twitter to voice complaints(or praise) and it is good to get a real time look.
Don't just go off what people on WHT say. Take it as inspiration to find out more...
A. Pricing(5 out of 5)
They had another promo for VPS $5 for the first month on any of their VPS plans. Which is an amazing good way to trial. On the norm, their prices start at $20 for a 1 GB VPS.
I think they are incredibly priced. The VPS are managed(but it's more like an enhanced Semi-managed VPS). For my needs, it was applicable. Migration, Cpanel set up, Server configuration/secure, etc etc
Things like litespeed installation are not supported under their Management. I've decided to go without litespeed for the month to test my experience without it(Spoiler alert: I prefer litespeed)
B. Set-up time, Migration and getting started(4.5 out of 5 stars)
Signing up for their Cloud VPS was easy....and fast.
The migration process was smooth, it did take a little longer than I am used to BUT all in all it worked out well enough and they did it correctly with no issues for my site.
C. Support( 4 out of 5)
I'll give Support a 4 out of 5. this is probably one of the few companies I've had that
1. Seems competent
2. Lacks the ego/arrogance I've seen at some hosts
3. Is actually useful
I knocked of .5 points due to the fact their phone service is only available during 9-5 hours. It's good they have it(when many don't) but there have been sometimes when I wanted to call in after hours but couldn't. Also, the phone experience isn't bad but it isn't quite as....smooth as some other hosts.
I knock off another .5 points because there are many times when your problem is escalated to Level 2 or higher, which sort of bothers me only because that means I sort of just wasted my time talking to you.
Otherwise, they are a friendly bunch and as cheesy as it is, I love the fact that their signatures they have some silly name "Tech Ninja" or "The Tech Guru" or something like that. It's silly and trivial but makes them seem a little less robotic and more like everyday people.
D. Performance & Uptime(3 out of 5 stars)
The No Score doesn't indicate good or bad. Here's what it is...I've had a the same software(IPB) for years and using it on various hosts, including shared hosting. I've had the same exact mods and the same overall activity and visitor amounts.
I really haven't had any issues with performance whatsoever or a host(except the shared) telling me I am using too much CPU/Ram.
However in the past month with ASO, my site has gone down quite a few times. 500 errors here or there and as long as a couple of hours.
They are telling me it is due to my site overloading the server and this or that. Problem with this is
1. It happens sporadically...my site does not go down everyday. It's usually every couple of days and around the same time of day(usually midday/early evening).
Why not more consistent? My traffic is the same and I haven't made any changes, so why doesn't the site go down every day if it has the same consistent use?
2. Based off the above, why don't I have these same issues with my past host I had?
It's quite annoying when the site goes down or goes slow. And this is where the phone support is good to have but often times than not, they are unavailable.
That said, the support on live chat usually has to reach out to the technicians but they usually do respond and fix it in a timely manner so I am not completely UNHAPPY with them.
When the site isn't going down and is running with no problems, it is fast and it generally feels good to use.
I also don't like that there is no guarantee for their VPS. They give you a guarantee uptime with Shared hosting and if they fail to meet it, they will compensate you. However, VPS customers don't get that luxury. A bit odd to me really.
E. Overall
I haven't officially decided but I am leaning towards leaving A Small Orange and venturing elsewhere. Am I unhappy with them? By no means, I am not.
Friendly support can make the world of difference and having much experience with less than friendly or helpful staff, I know the difference and I appreciate it.
But my present site(IPB forum) is not compatible with it. I am sure I could probably work with them to optimize the server and site a bit better. I am not sure if it is my site that is the problem, ASO that isn't or a mix of both. But I do know I never had an issue with it on the other companies I've used.
However, I also want things such as litespeed which is not officially supported. Not all companies do support installing it and keeping it up to date and all that good stuff.
For my present site, I do not think ASO is a great fit. It's good but could be much better. That being said, aside from some issues here or there, ASO is a company I do plan to continue using for my other projects(Shared or VPS related) and a company I truly don't mind recommending to friends.
This is what I mean...take the time to research, take a risk and experiment and if they suck(any host in general), leave. It's always good to choose a host with a moneyback guarantee and in ASO's case they have a 90 day guarantee. Which is awesome.
ASO is a host that is owned by EIG. It's not EIG...It's not hostgator or bluehost or fatcow or any of those other known bad EIG brands. It's ASO. Let ASO stand on its own with its own name and reputation. That's not to say that ASO may not become yet another bad EIG host. It's saying, judge them for who they are presently and not off what another EIG hosts is known for.
My overall rating for ASO is 4.1 out of 5 stars.
1. Seems competent
E. Overall
