Any way to use the CSF visual web interface WITHOUT having cpanel?
Belucci
Ok CSF supports integration in cpanel, directadmin and webmin right?
Is there a way to use it's web interface configuration thing if I don't have any of those?
I'm with vestaCP if that helps.
nunim
VPS Junkie
There's a WebUI built-in to LFD, however it eats CPU while it's running.
Seems like the cPanel/Webmin UI is just some CGI/Perl scripts, so you should be able to use them to control CSF/LFD without having the run the control panel.  This is something I've been meaning to look into for some time but haven't had a chance.
Belucci
How does one access this WebUI though? I couldn't find anything about it except as modules for 3rd party panels :(
TekStorm - James
Search your csf.conf for UI_PORT; ultimately, finding its Integrated User Interface section. You can configure settings there.
nunim
VPS Junkie
You should have a section like this in your csf.conf:
# SECTION:Integrated User Interface
# Integrated User Interface. This feature provides a HTML UI to csf and lfd,
# without requiring a control panel or web server. The UI runs as a sub process
# to the lfd daemon
# As it runs under the root account and successful login provides root access
# to the server, great care should be taken when configuring and using this
# feature. There are additional restrictions to enhance secure access to the UI
# See readme.txt for more information about using this feature BEFORE enabling
# it for security and access reasons
# 1 to enable, 0 to disable
UI = "0"
# Set this to the port that want to bind this service to. You should configure
# this port to be >1023 and different from any other port already being used
# Do NOT enable access to this port in TCP_IN, instead only allow trusted IP's
# to the port using Advanced Allow Filters (see readme.txt)
UI_PORT = "6666"
# This should be a secure, hard to guess username
# This must be changed from the default
UI_USER = "username"
# This should be a secure, hard to guess password. That is, at least 8
# characters long with a mixture of upper and lowercase characters plus
# numbers and non-alphanumeric characters
UI_PASS = "password"
# This is the login session timeout. If there is no activity for a logged in
# session within this number of seconds, the session will timeout and a new
# login will be required
# For security reasons, you should always keep this option low (i.e 60-300)
UI_TIMEOUT = "300"
For more information. search for 23. in the following document:
http://download.configserver.com/csf/readme.txt
As I said, I've found that it eats CPU while running, so running it via Apache or other webserver would be more ideal.
Belucci
ok that completely solves my problem then :)
How much CPU it eats though?
So, if ran via webmin, it will be using apache and be more effecient, right?
Does webmin give significant load?
