AnyNode - CVZ-512 Beta Review
FHN-Eric
So, AnyNode has been providing a beta vps. The beta vps is their CVZ-512 located in Chicago. Overall, the vps has really good uptime, it is really fast almost no lag at all.  The best part about AnyNode is the support they provide. The best feature is defiently the custom control panel they made, easy to find what your looking for. I would defiently recommend AnyNode to anyone looking for a vps.
Please update the thread with some actual stats. Would be nice to see some results similar as what is shown in the other review threads here. The more info the better!
anyNode
Thanks for the review!
As others have been saying, maybe you should provide some stats/tests etc.
FHN-Eric
