Apt-get Repo Check help
Munzy
I am looking for a way to check if one mirror is the same as another. What file should I use to check against.
From what I have looked up I think it is the source file, but I may be mistaken.
Just looking for a little guidance.
TruvisT
Server Management Specialist
Are you looking to check the MD5 sums for the example to check file authenticity?
Munzy
Lets say there is a debian repo.
There is a mirror of this repo.
I want to check if the mirror repo is on the same version / sync'd with the master.
What file(s) would I check to confirm this.
Im not trying to verify every file in the mirror.
Serveo
Are you hosting that mirror yourself or you want to check up a 3rd party mirror? Which mirror are you using?
Munzy
I want to do both, I host a mirror myself and I want to check if it is up to date with the master.
