What is, in your opinion, the best server benchmarking script to run on new servers? What do you prefer? Use the upvote buttons on the response to signal your agreement and comment with any/all opinions.
I think the best server benchmarking script depends on what you're aiming to test - disk space, CPU, software, etc. For example, I heard that this one is good for PHP, but it also depends on which PHP version you're using ...
Well, I would recommend IOzone or dd, Blogbench or phoronix test suite
Now you made me curious What would you recommend?
