Best low cost CDN?
Garcia
I dont know much about content delivery networks and there are a lot of options... what is the best choice for less than $10usd monthly? My visitors are mostly from USA and UK. My website speed is okay but I want to make it even faster for all users.
First thing you should do is examine your 'site' or 'server' and do overview of configuration. Some tips:
- Google Chrome's Debugger can 'audit' the webpage to give tips on speeding it up
- Use gzip compression if you can, since smaller chunks of data (=< MTU) won't fragment and give a nice speed boost.
- I'd probably suggest using mod_pagespeed on the server itself
- If you're doing SSL based stuff, mod_spdy (but this breaks on certain types of 301 redirections, use with caution)
- If you're using PHP
-- Use mod_ruid2 instead of SuPHP since it's much faster overall
-- Use something like an opcode cacher to save at least 50% of overhead when compiling code on the stack
Of course, that's what I would do first instead of dumping money into a CDN that may or may not be 'optimal'.
For $10 monthly the best choice is usually to not use a CDN.  Using a cheap CDN often does more harm than good and may actually slow your site down.  The performance of cheap CDNs often leaves a lot to be desired...
sv01
Slow but sure
good point Monkburger :D
@Garcia depend how much bandwidth you need?
maxcdn has $9 for 100 GB/m
cdn.net, keycdn, stylexnetworks pay as you go.
devonblzx
Using a global DNS service is a cheaper way of reducing connection times then always taking advantage of common hosted files like Google's libraries.  When a user is connecting to your site from around the globe, it could be adding half a second just on the DNS lookup.  Then the good things about the hosted libraries (like jquery for instance) is not just the CDN Google and other sites have but the fact that many other sites use them so they have a higher potential to already be cached in the user's browser.
Mah Pants
Totally non-joking, I know FRCorey sells OnApp CDN with a pay-as-you-go method.  Knowing FRCorey, I'd say it's probably a solid service.
mikeyur
CDNify is pretty solid, they have a $10/mo plan: https://cdnify.com/
Used them for the last 6 months or so. I know they have a recurring 20% off coupon floating around as well.
Mid
I have no experience with these, but
cdn77 charges $49/TB for US/EU location (not per month, you can use it until you consume I think)
So, per GB cost comes to 0.05/GB is probably the cheapest I think
But anyway CDN is more costlier (5 to 10 times?) than normal vps/dedi I think (assuming vps providers don't oversell bandwidth like done in shared hosting). If you could have multiple (3) VPSes and do load balance with DNS, that would be cheaper than having a CDN I think (unless you want absolute low latency with 100s of servers across the globe).
The low end vps providers bandwidth cost varies from 0.005/GB to 0.01/GB.
Some unmetered ones might even workout to 0.001/GB (like ovh/etc) but not sure how reliable it would be.
cloudvps claims to offer a free global CDN, check for yourself.
Art
My choice is[SIZE=12pt] [/SIZE]INXY.COM.[SIZE=12.5pt] Indeed, they have the lowest prices in the Net. Besides, they provide free trial (20Tb of traffic), and you need to pay for consumed traffic only![/SIZE]
graeme
A CDN may not be the best solution. have you done these:
  1. Minimise and combine JS files (there are tools for that)
  2. Minimise and combine CSS files (there are tools for that too)
  3. Optimise images, reduce quality of JPEGs (on must sites no one will notice), use SVG where possible (especially if you have things like large diagrams)
  4. Check all HTML, JS and CSS is GZipped
  5. Remove third part widgets and Javascript unless you really need them (on a lot of sites the slowest thing to load are ads, analytics, social sharing buttons and assorted third party crap).
Interesting offers on CDN.
Their website made me chuckle though:
"What peculiarities do our web hosting solutions have?"
https://www.inxy.com/dedicated-servers/
Peculiarities isn't a word anyone should ever use in sales material.
ajju11
Online Matka Play has evolved dramatically since its humble beginnings in the 1950s as a lottery system based on cotton prices from the New York Cotton Exchange. What started with paper slips and local bookies has transformed into a digital phenomenon accessible to players worldwide.
