Django and Ruby on Rails security issue
marlencrabapple
Cookies? Couldn't this be easily avoided if you just used some sort of hash of the users IP to check if the cookie is legit? Seems simple enough.
Not really up to them to implement it though - that's up to the developer using RoR/Django.
marlencrabapple
After reading into it a bit it looks like they were using a function built into RoR and Django that should've done all of it on its own. Isn't that the entire point of a framework? They're supposed to do things the right way so you don't have to try your hand and screw it all up.
Yup that's correct.
If you have to do everything on your own you are not using a "framework".
