ModulesGarden
Welcome back everyone!
We are excited to tell you a few words about our very latest updates of two WHMCS modules.
1. Virtuozzo VPS For WHMCS 1.5.0
The module has just been equipped with a handful of extra tools that your clients will surely appreciate. Especially the keenly awaited possibility to:
Learn more about Virtuozzo VPS For WHMCS 1.5.0!
2. Hetzner VPS For WHMCS 1.1.0
This module is the very latest addition to our WHMCS collection, and a moment ago it received its first major update. The 1.1.0 version is now up for grabs on our website, introducing several enhancements to password management.
Most importantly, as of now both you and your clients will be empowered to freely change the server password when needed. Also, your audience will be able to preview the new password from your client area directly every time they rebuild their machine, or create a new machine without using the SSH key.
Learn more about Hetzner VPS For WHMCS 1.1.0!
Need Custom Software Development For Your Business?
Specially for you we will adapt an application and its design to your own needs, create a new module or even a completely new system built from scratch!
- Rebuild any of the owned machines or containers using one of the supported OS templates
- Change the hostname of a newly set up machine to the one that suits them best
- Means to enable or disable the remote console in a manual manner straight from your client area – here you may also decide if the console should be enabled or disabled by default after product creation
