Extremely Simple My Current IP Site
Munzy
As always, there is a lot of sites featuring what IP you are using currently. This can be for making sure your proxy / vpn is working or just wondering what your current ip might be.
As such I made a very very simple page that simply states what your IP is and nothing else. I wanted to do this to avoid the extra confusion that some sites have showing way to much information.
It works with IPv6.
Feel free to use it as you wish!
https://www.enjen.net/myip/
other forms:
RAW : https://www.enjen.net/myip/raw/
JSON : https://www.enjen.net/myip/json/
If you have any suggestions or wants, let me know and I'll gladly whip up something.
w.james
You can also just type "ip" into google, or even startpage or duckduckgo.
Ha awesome! that almost makes up for them changing the digital storage conversion to 1000 MB = 1 GB, forcing you to add an `i` in the middle (MiB) for it to work like it use too
We were talking about that very issue on IRC the other day!
