Fastest hard-disk... post yours!
Minmeo
root@srv:~# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 2.31474 s, 464 MB/s
This is a ramnode ssd cached vps and it is the fastest I have for disks. What about you?
PwnyExpress
root@UWAXT7AHNO4BTSC:~# dd if=/dev/zero of=test bs=32k count=32k conv=fdatasync
32768+0 records in
32768+0 records out
1073741824 bytes (1.1 GB) copied, 2.04894 s, 524 MB/s
This is on a Hyper-V VM with it's storage backed on an InfiniBand QDR link to a Windows Scale-out File Server cluster that's hooked up to a SAS JBOD via a SAS switch.
Virtovo
8 Disk HDD Raid 10.  No SSD caching
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 1.67747 s, 640 MB/s
Nett
Article Submitter
16384+0 records in
16384+0 records out
Nice result :)
GIANT_CRAB
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 0.00001 us, 1258 GB/s
Single WD disk.
dano
KVM virtual machine on an lightly used host machine. 4-disk raid10,no ssd or ssd cache.
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 1.48229 s, 724 MB/s
blergh
16384+0 records in
16384+0 records out
16384+0 records in
16384+0 records out
HW or soft?
mtwiscool
i,m so going to post mines tonight.
on a test vm set up.
1 WD Green HDD but disk io you won't believe.
It is a test for some paid vps planning. :)
xen pv to be used.
mrwright
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 1.23743 s, 868 MB/s
TruvisT
Server Management Specialist
[[email protected] ~]# dd if=/dev/zero of=meow bs=64k count=16k conv=fdatasync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 0.740006 s, 1.4 GB/s
I have some disks from the 80's so I will dig those out and see how slow, I mean fast, they are :D
dave
Here's my local VirtualBox instance running CentOS off an external WD usb 2.0 hard drive.
# dd if=/dev/zero of=/tmp/test bs=64k count=16k conv=fdatasync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 45.5353 s, 23.6 MB/s
Did I win something?
