Fix Credssp Encryption Oracle Remediation Error
rcchost
In this video we will see how to fix An authentication error has occurred on RDP connection.
The function requested is not supported Remote computer: bensminger This could be due to CredSSP encryption oracle remediation. For more information, see https://go.microsoft.com/fwlink/?link... OR CredSSP Encryption Oracle Remediation error on your PC.
This error appears when you try to establish rdp connection from your computer and can’t rdp through your pc(Remote desktop connection/remote desktop client from microsoft).
This solution will work on Windows (Windows Vista,Windows 7, Windows 8, Windows 8.1,Windows 10(Windows 10 Home,,windows 10 1803,windows 10 enterprise,windows 10 pro), Recent Windows Server versions(Azure,server 2012 r2,server 2016,server 2008 r2,Windows Server 2016), includes all 32bit and 64bit Versions in this list).
Credssp encryption oracle remediation problem also appears on some devices which are updated operating system(some windows 10 update/after update). Credssp encryption oracle remediation not available on your device if you are using older version of Microsoft Windows operating system. Sometimes credssp encryption oracle remediation error shows when you try to rdp to windows(Windows server or other OS) in vmware or Oracle VirtualBox.
Credssp encryption oracle remediation patch is also available on latest windows update(may not available for all devices).
In this video we are going to two methods for Oracle Remediation error resolution.
Method 1 uses Group Policy Editor(gpo) if you have Encryption Oracle Remediation available in Group policy editor.
Method 2 uses Reg Key/Regedit if Encryption Oracle Remediation not available available in Group policy editor. If you are getting this error using Oracle VirtualBox you may need to install oracle vm virtualbox extension pack and windows remote desktop port in your router if you are on wifi.
After using one of these method on your pc hit mstsc in Run(In Windows) to start rdp (Windows Remote Desktop Connection).
