Help with nginx template syntax :(
Greg
I need to disallow access to xmlrpc.php server wide for anything but localhost by adding it to this template below.
No idea if I can add it to the existing such block that forbirds wp-login.php or should add new one?
Is that the most effective way to do it?
Sorry for the stupid question but I'm very new to nginx and need that urgently since the server is crashing every hour or so :(
and it's a sunny Saturday
server {
    listen      %ip%:%proxy_port%;
    server_name %domain_idn% %alias_idn%;
    error_log  /var/log/%web_system%/domains/%domain%.error.log error;
    location / {
location ~ wp-login.php {
    allow 127.0.0.1;
    deny all;
        proxy_pass      http://%ip%:%web_port%;
        location ~* ^.+\.(%proxy_extentions%)$ {
            root           %docroot%;
            access_log     /var/log/%web_system%/domains/%domain%.log combined;
            access_log     /var/log/%web_system%/domains/%domain%.bytes bytes;
            expires        max;
            try_files      $uri @fallback;
    location /error/ {
        alias   %home%/%user%/web/%domain%/document_errors/;
    location @fallback {
    location ~ /\.ht    {return 404;}
    location ~ /\.svn/  {return 404;}
    location ~ /\.git/  {return 404;}
    location ~ /\.hg/   {return 404;}
    location ~ /\.bzr/  {return 404;}
    include %home%/%user%/conf/web/nginx.%domain%.conf*;
Munzy
Honestly that code looks like shit, my guess is you are crashing to random loops or errors in that config. Doesn't even look like everything is in the server bracket.
Greg
well that's the default vestacp template with just this part added
location / {
allow 127.0.0.1;
deny all;
so you sure it is that bad?
anything constructive to say about how to actually do it?
I use plugins like 'bruteprotect' and 'disable xml-rpc pingback' instead of trying to do it in a nginx location block...
I'd add a new location block for the xmlrpc.php block.
If your server is constantly crashing try disabling access and error logging inside the 2 location blocks to reduce server load/disk writes
location = /xmlrpc.php {
        deny all;
        access_log off;
        error_log off;
what do the logs show when it crashes?
Greg
        deny all;
        access_log off;
        error_log off;
well apache status was showing like 200 processes and 90% of them occupied by that same file from the different sites
probably someone taking advantage of my server to attack others
thank you! I'll try that code later
you guys are great
