Help with VPS with 5 ips
sasa123sa
Hello,
I need help with seting up VPS proxy with 5 ips.
So my problem is that i get VPS server with 5 different ip and i make 5 VMs when i set up ip adresses in putty for each individual VM[exsample i have ip1,2,3,4,5 and VM1,2,3,4,5] and when i check the whatismyip.com it show me same ip for all VMs IP1...
So i set up in putty IP1 for VM1;IP2 for VM2....But i always get same ip....
So my question is can you help me to separate all ips so all 5 VMs Have unique IP?
TNX in advance!
RiotSecurity
-facedesk-
You realize you could use nginx server if you want to do http proxy, then do ip1.domain.tld = route though first ip, etc.
-facedesk-
Beefer
If you have a problem related to your VPS, then the first thing you should do is ask your web hosting provider. If they can't help you out it may be time to start looking for a better provider and then you can post your question on this forum of course. All in all to me it seems not really a complicated technical issue which means that, if you have a reliable web host, they should be able to help you out in minutes.
budi1413
What kind of proxy application do you use? And i don't think you need 5 more nested vm for that lol.
