How many of you use Cloudlinux with CageFS?
risharde
Hi everyone, a little research into Cloudlinux and CageFS... how many of you use it? Please let me know!
Thanks
k0nsl
Bad Goy
I'm currently using it on all my cPanel servers. Why this is something interesting to know is not something I can relate to. But each to their own, eh! :D
Best wishes,
-k0nsl
risharde
Hi k0nsl, I'm actually working on a plugin that currently requires an external directory for the configuration files. CafeFS is doing its job but is hindering the user from being able to access the directory. What  I'm confused about is where do I put config files that should not be edited by the user directly via filemanager if the user only has access to /home/username in which they can edit the files. What's even worse is that cpanel runs under the user so in order to edit the file, the user would have to have rw access. Hope this explains the issue and my dilemma.
