How to Choose a VPS Hosting?
johner
A VPS hosting can be considered a special web hosting service, not because of the type of service it provides, but because of the way in which it is developed and implemented. As you have already deduced, a VPS is a virtualized server, which runs on a physical server with certain characteristics, and is assigned virtualizing by means of software.
The virtual space acts as the virtual server with its own IP address and specific configurations such as space, memory, RAM, processing speed and other characteristics of a physical server. A VPS is a profitable option, which is why it is one of the most chosen in the world. There are a large number of VPS hosting providers, here are some features you should keep in mind, so you can choose a VPS server correctly.
1. Managed and Unmanaged VPS
A VPS is a server that adapts to the needs and capabilities of each person. You can find a managed service and an unmanaged one. In short, with the managed service you will have the support of experts for the problems you may have. This type of VPS service is suitable for those who start in the world of the web and want to have the best performance in terms of web servers.
A managed service will not have the support of a managed VPS server, but it will have some basic and limited support. Undoubtedly, this type of VPS service is ideal for those who already have experience with servers.
2. Operating System
There are two basic operating systems that are very popular for virtual servers, these are Linux and Windows. Linux is easier to use and costs much less than Windows because it is an open source operating system. It also supports a wide range of applications compared to Windows. However, there are many applications that are compatible with Windows. If you work at with.Net or Visual Studio, you should definitely use Windows.
3. RAM
The random access memory, or RAM, of the virtual server, is very similar to RAM on your PC. The more RAM size you have, the greater your work capacity. For a faster load, it is suggested to have at least 512 MB of RAM in your VPS. However, there are many VPS providers that offer 1GB of VPS RAM at affordable price rates. In HostDime Colombia, you find basic plans with 1.5 GB of RAM.
4. Speed
The operating time of a server is something fundamental. Many providers offer 99% of operation, but many times this is not fulfilled. The best way to find the real results is to look for comments and testimonials from the web hosting provider.
5. Customer Support
It is vital to prefer the VPS provider that offers 24-hour customer service. It is also important to know the channels of attention, that is, by calls, live chat, tickets and email; HostDime Colombia offers all this, besides being 100% in Latin Spanish.
6. Price
The price is one of the factors that help to decide when buying a VPS server. You can choose the most economical, but you must consider if this provides the above characteristics. You must be clear that a managed VPS may be worth more compared to one that is not administered.
qtechservers
Make sure the hosting company maintains a full backup of the server in case an emergency arises and the server needs a full restore. Also, check with them the server upgrade options.
hazelmadison
Here are a few things that listed might help you choose the VPS that suits your project.
The quantity of the resources you require.
Choice of OS.
Back-end operations management.
Root access
Location of your web host
Customer support
