KVM Performence issue
SubZeroFX
Hello,
We've setup KVM on CentOS.
Our KVM VPS works just fine when VPS configuration is up to 2 GB with 4 cores. Guest system is Windows Server 2008. That 2 GB VPS can use fully it's resources and all applications run just fine.
But the problem occurs when we want to run VPS with 10 GB and 8 cores.
We can't even use 40% of VPS RAM (CPU on 10%) and that VPS just starts to lag via Remote Desktop Control.
Our hardware is just fine as we have a lot of physical resources left (RAM/HDD/CPU).
Is there some limit that KVM can run on single VPS?
Virtovo
Hello,
Are you in control of the host node or do you only have VPS access?
