Low cost server which is right for me ...
Discussion in 'Hosting Talk & Reviews' started by Charmaine, Feb 8, 2019.
  1. Charmaine
    Charmaine Member
    55
    0
    May 22, 2017
    Comparing servers from xeref.com and legionbox.com, which plan is better to sign up with?
  2. Orestock
    Orestock Member
    109
    7
    Oct 16, 2014
    I've been using Cloudarion.com service to host multiple websites, including a couple of my clients.
    I also liked their cpanel control panel better than other control panel interfaces I have used.
    Highly recommended them.
  3. Archer-arrow
    Archer-arrow New Member
    6
    0
    Feb 11, 2019
    #vpsboard on freenode
    What specifically is included in the plan that you are considering? Sure, you know that it includes X RAM and Y bandwidth – but what does that mean?
  4. Derossi
    Derossi Member
    94
    3
    Jun 28, 2017
    I'd like to draw your attention to CentoHost.com servers: Own Data Center in Europe - Bosnia and Herzegovina
    Get started with a Dedicated Server within your budget. First 3 months - 35% OFF.
  5. vikmanager
    vikmanager Member
    45
    2
    Sep 30, 2017
    I thing you need to try server from vikhost.com. with 1Gbps network connection, 99.99% uptime and professional support.
  6. Jensir
    Jensir New Member
    21
    0
    May 16, 2017
    That is better you if can start mentioning some kind of the server specifications as well as budget.
    As for the cheap providers I can recommend you to have a look at hostingsource.com, asvhost.com or ovh.net
