Output of lscpu on a CentOS OpenVZ Container
Geek
Technolojesus
So on the node level the lscpu output is fine, but if you try the same command in a CentOS* container, an error is thrown. Then there's a weird thing going on with a couple of the dual L5520s which, using Ubuntu templates, gives an lscpu output displays an incorrect core/thread total (would expect 16 in those cases). Also, Ubuntu seems to respond correctly under single proc environments (E3s) as far as I can tell.  Has this always been the way of things for CentOS containers? I've seen this popping in and out of cPanel error logs.  I'm almost certain this is easily reproduced... anybody out there?
CentOS 6.5 x86_64 (container)
[root@hampton logs]# lscpu
lscpu: failed to determine number of CPUs: /sys/devices/system/cpu/possible: No such file or directory
Scientific Linux 6.5 (container)
[root@labassu ~]# lscpu
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                24
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 44
Stepping:              2
CPU MHz:               2668.000
BogoMIPS:              5333.70
Virtualization:        VT-x
Ubu 12.04 (container)
root@jax-ctq02:~# lscpu
CPU(s):                24
CPU family:            6
Model:                 26
Stepping:              5
CPU MHz:               2266.698
BogoMIPS:              4533.39
A few (correct) node examples:
[root@********** ~]# lscpu
CPU(s):                24
On-line CPU(s) list:   0-23
Thread(s) per core:    2
Core(s) per socket:    6
Socket(s):             2
NUMA node(s):          2
CPU family:            6
Model:                 44
Stepping:              2
CPU MHz:               2668.000
BogoMIPS:              5333.19
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              12288K
NUMA node0 CPU(s):     0-5,12-17
NUMA node1 CPU(s):     6-11,18-23
[root@************* ~]# lscpu
CPU(s):                24
Socket(s):             2
NUMA node(s):          2
CPU family:            6
Model:                 44
Stepping:              2
CPU MHz:               2668.000
BogoMIPS:              5333.19
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              12288K
[root@************** ~]# lscpu
CPU(s):                16
On-line CPU(s) list:   0-15
Core(s) per socket:    4
Socket(s):             2
NUMA node(s):          2
CPU family:            6
Model:                 26
Stepping:              5
CPU MHz:               2266.698
BogoMIPS:              4532.67
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              8192K
NUMA node0 CPU(s):     0-3,8-11
NUMA node1 CPU(s):     4-7,12-15
devonblzx
Judging that it didn't work for one template, I'm going to assume that /sys/devices/system/cpu/possible isn't virtualized by OpenVZ.  In the one case, /sys/devices/system/cpu/possible may exist only because the template was made from a running system.  Therefore the template actually contains a static file of /sys/devices/system/cpu/possible.
I could be wrong, you could verify if the template itself has that file or if the file exists after the container is stopped, but it would make sense why it doesn't show up in CentOS and it is reporting invalid information.
Geek
Technolojesus
Eh, as far as I can tell it started happening right after  http://rpm.pbone.net/index.php3/stat/22/idpl/21351544/com/changelog.html or so.  lscpu reports correctly under SL 6.4, but behaves incorrectly under 6;5.  There's a good 5+ lscpu segfault/coredump fixes between 6_4 and 6_5 so I wouldn't be shocked if one of those broke it.  I imagine some things are handled differently in the case of Deb/Ubu, At least I can 'lscpu -p' without a fail.  Oh well, that's about all I'm going to put into that for now.  Don't know if it's bugworthy or expected....
