Provider: AnyNode
Plan: OpenVZ 1GB VPS
Price: 4.40$ per month with Promocode
Purchased: 08/2013
Hardware information:
Overall experience:
Whenever a provider is telling you that they are switching datacenters you might feel not that good. But the move from Chicago to Detroit is good.
I like the fresh location and the datacenter 123.net (AS12129) does have good upstream providers: Level3, Tinet, Savvis, and Cogent.
Look at the traceroutes to Europe: Level3/Tinet only.
I will update the review in January. If they keep this level (both 123.net and anyNode) it might become a good alternative to Chicago and Buffalo.
Network:
traceroute lemonde.fr:
traceroute dvhn.nl:
traceroute sueddeutsche.de:
traceroute washingtonpost.com:
traceroute to Atlanta:
Purchased: 08/2013
- cat /proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 16
model : 2
model name : Quad-Core AMD Opteron(tm) Processor 2356
stepping : 3
cpu MHz : 2300.081
cache size : 512 KB
physical id : 0
siblings : 8
core id : 0
cpu cores : 8
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt rdtscp lm 3dnowext 3dnow constant_tsc rep_good tsc_reliable nonstop_tsc unfair_spinlock pni cx16 popcnt hypervisor lahf_lm extapic abm sse4a misalignsse 3dnowprefetch osvw
bogomips : 4600.16
TLB size : 1024 4K pages
clflush size : 64
cache_alignment : 64
address sizes : 40 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 16
model : 2
stepping : 3
cpu MHz : 2300.081
cache size : 512 KB
physical id : 0
siblings : 8
core id : 1
cpu cores : 8
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
bogomips : 4600.16
clflush size : 64
power management:
- cat /proc/meminfo
Code:MemTotal: 1048576 kB MemFree: 808648 kB Cached: 69288 kB Active: 123148 kB Inactive: 101308 kB Active(anon): 85880 kB Inactive(anon): 69288 kB Active(file): 37268 kB Inactive(file): 32020 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 524288 kB SwapFree: 509240 kB Dirty: 20 kB Writeback: 0 kB AnonPages: 155168 kB Shmem: 2612 kB Slab: 15448 kB SReclaimable: 11688 kB SUnreclaim: 3760 kB
- dd
Code:dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync && rm -rf test 16384+0 records in 16384+0 records out 1073741824 bytes (1.1 GB) copied, 11.8903 s, 90.3 MB/s
- wget
Code:wget cachefly.cachefly.net/100mb.test -O /dev/null --2013-09-01 02:22:20-- http://cachefly.cachefly.net/100mb.test Resolving cachefly.cachefly.net (cachefly.cachefly.net)... 205.234.175.175 Connecting to cachefly.cachefly.net (cachefly.cachefly.net)|205.234.175.175|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 104857600 (100M) [application/octet-stream] Saving to: `/dev/null' 100%[===============================================================================================================================>] 104,857,600 6.01M/s in 11s 2013-09-01 02:22:31 (9.42 MB/s) - `/dev/null' saved [104857600/104857600]
- MongoDB
- Lighttpd (static sites)
- Ruby based sites
- Munin master
- Asking for the support of IPv6. They returned that IPv6 will be available on Septermber the 1st.
Overall experience:
Network:
2 216-234-102-9.static.123.net (216.234.102.9) 0.629 ms 0.644 ms *
3 4.53.76.157 (4.53.76.157) 13.187 ms 13.311 ms 13.284 ms
4 ae-11-11.car2.Detroit1.Level3.net (4.69.133.246) 102.259 ms 102.291 ms 102.294 ms
5 ae-7-7.ebr1.NewYork1.Level3.net (4.69.133.250) 100.453 ms 100.472 ms 100.428 ms
6 ae-10-10.ebr2.Washington12.Level3.net (4.69.148.50) 99.662 ms 4.69.201.62 (4.69.201.62) 99.751 ms ae-48-48.ebr2.NewYork2.Level3.net (4.69.201.50) 101.976 ms
7 4.69.201.85 (4.69.201.85) 101.567 ms 4.69.201.93 (4.69.201.93) 101.871 ms 4.69.202.57 (4.69.202.57) 102.167 ms
8 ae-41-41.ebr2.Paris1.Level3.net (4.69.137.49) 99.847 ms ae-44-44.ebr2.Paris1.Level3.net (4.69.137.61) 100.752 ms 101.160 ms
9 ae-92-92.csw4.Paris1.Level3.net (4.69.161.106) 100.321 ms ae-72-72.csw2.Paris1.Level3.net (4.69.161.98) 100.983 ms ae-82-82.csw3.Paris1.Level3.net (4.69.161.102) 100.752 ms
10 4.69.168.7 (4.69.168.7) 103.183 ms 102.234 ms 4.69.168.199 (4.69.168.199) 145.158 ms
11 ONLINE-SAS.edge4.Paris1.Level3.net (212.3.235.54) 102.278 ms 101.122 ms 102.315 ms
12 6k1-1046.dc2.poneytelecom.eu (88.191.1.254) 100.040 ms 101.511 ms 99.992 ms
2 216-234-102-9.static.123.net (216.234.102.9) 0.601 ms 0.571 ms *
3 xe-2-3-2-3506.chi11.ip4.tinet.net (216.221.159.225) 7.733 ms 7.673 ms 7.646 ms
4 xe-8-3-0.lon11.ip4.tinet.net (213.200.80.57) 91.790 ms xe-5-0-1.lon10.ip4.tinet.net (89.149.184.130) 93.020 ms xe-5-1-0.lon10.ip4.tinet.net (89.149.187.141) 93.953 ms
5 bit-gw.ip4.tinet.net (77.67.75.70) 93.633 ms 93.625 ms 93.594 ms
6 806.xe-0-0-0.jun1.bit-2a.network.bit.nl (213.136.1.109) 106.876 ms 107.749 ms 805.xe-0-0-0.jun1.bit-1.network.bit.nl (213.136.1.105) 108.829 ms
2 216-234-102-9.static.123.net (216.234.102.9) 23.309 ms 23.313 ms 23.279 ms
3 tengigabitethernet8-3.ar4.chi2.gblx.net (64.214.140.201) 7.719 ms 7.862 ms 7.849 ms
4 vodafone-procurement.tengigabitethernet8-2.ar3.ham1.gblx.net (209.130.173.2) 106.657 ms 106.719 ms 106.698 ms
5 92.79.211.209 (92.79.211.209) 107.010 ms 107.011 ms 106.992 ms
6 92.79.202.50 (92.79.202.50) 114.499 ms 113.673 ms 113.735 ms
7 92.79.203.170 (92.79.203.170) 112.575 ms 112.540 ms 112.519 ms
8 188.111.149.118 (188.111.149.118) 116.974 ms 117.099 ms 117.016 ms
9 145.253.180.27 (145.253.180.27) 116.785 ms 116.656 ms 116.608 ms
2 216-234-102-9.static.123.net (216.234.102.9) 8.909 ms 8.807 ms 8.818 ms
3 te4-1.1060.ccr01.dtw04.atlas.cogentco.com (38.122.60.45) 43.493 ms 43.513 ms 43.444 ms
4 te9-3.ccr01.tol01.atlas.cogentco.com (154.54.31.22) 80.499 ms 80.433 ms 80.373 ms
5 154.54.89.121 (154.54.89.121) 7.522 ms 7.517 ms 154.54.89.129 (154.54.89.129) 7.494 ms
6 be2004.ccr21.ord03.atlas.cogentco.com (154.54.5.10) 7.495 ms be2003.ccr21.ord03.atlas.cogentco.com (154.54.29.22) 7.878 ms be2004.ccr21.ord03.atlas.cogentco.com (154.54.5.10) 7.993 ms
7 abovenet.ord03.atlas.cogentco.com (154.54.10.198) 7.422 ms 7.350 ms 7.270 ms
8 xe-4-2-0.cr2.ord2.us.above.net (64.125.22.213) 7.523 ms 7.520 ms 7.448 ms
9 xe-4-0-0.cr2.lga5.us.above.net (64.125.31.73) 21.488 ms 20.946 ms 20.908 ms
10 xe-2-2-0.cr2.dca2.us.above.net (64.125.26.105) 26.100 ms 26.146 ms 26.123 ms
11 xe-7-2-0.cr1.dca2.us.above.net (64.125.26.41) 65.270 ms 65.304 ms 65.146 ms
12 xe-1-1-0.mpr3.iad1.us.above.net (64.125.31.113) 26.207 ms 26.238 ms 26.219 ms
13 64.124.201.150.allocated.above.net (64.124.201.150) 26.621 ms 26.653 ms 26.678 ms
14 208.185.109.100 (208.185.109.100) 27.151 ms 26.779 ms 26.822 ms
2 216-234-102-9.static.123.net (216.234.102.9) 0.814 ms 0.735 ms 0.693 ms
3 xe-2-3-2-3506.chi11.ip4.tinet.net (216.221.159.225) 7.640 ms 7.575 ms 7.538 ms
4 xe-9-2-0.atl11.ip4.tinet.net (141.136.109.205) 38.621 ms xe-8-2-0.atl11.ip4.tinet.net (141.136.109.201) 38.912 ms xe-7-2-0.atl11.ip4.tinet.net (141.136.109.197) 95.930 ms
5 ramnode-gw.ip4.tinet.net (77.67.78.254) 38.092 ms 37.988 ms 38.741 ms
