This may help out anyone here using SolusVM.  It will let you define what % usage you want to run IP blocks to and adjust the IP block priorities as such.  As of this posting Solus hasn't release this feature to their production tier yet but it will be available in 1.16.13 or you can /scripts/upcp-beta on your master to get it.
It's designed to be run on a cron. I wouldn't recommend running it any more often than once an hour or so.
https://github.com/neonardo1/solusvm-80ipblock
