Step by step guide to load mt4 on vps
selenium3lo
You are a Forex trader and need to load Meta Trader 4 on your VPS? This article will help you to do so. But, before starting the configuration, let us start with some basic definitions:
What is Forex? or Foreign Exchange?
Foreign exchange (Forex) is a known expression defined as a network of buyers and sellers who transfer international currency at an agreed price. The general people, companies, and central banks convert one currency into another in this manner. You have probably traveled abroad at some stage, and chances are you have made a forex transaction as well, but probably for practical purposes. This item is an important purpose of Foreign exchange. However, the vast majority of currency conversion is undertaken to earn a profit. Much of the Forex trading today is moving in the direction of becoming computerized and technological. But, why we need to load Meta Trader for forex? or, why need to load Meta Trader 4 on your VPS? In the next paragraph, we will answer you.
Why use VPS for Forex trading?
A virtual private server (VPS) is a special type of server which is housed on the same computer as several other virtual private servers—this is why they are termed “virtual.” Although they’re all located on one machine, they can operate independently of each other. You’re guaranteed a certain amount of space, RAM, and transfer allowance per month. Your VPS has its own dedicated power supply and offers flexibility, stability, and convenience. In very short, VPS is a cloud-based desktop PC.
What is MetaTrader?
Metatrader is a kind of software that connects to the different trading platforms and allows to trade in them through a computer or smartphone. Basically, Metatrader is the link between the two. This software is mostly used by Forex traders who have an opportunity to choose the broker with which they wish to trade, as long as it is compatible with the Forex platform. In this way, and in case it is not compatible, Metatrader acts as a bridge that will allow you to trade with the broker of your choice within the same platform.
With that info in mind, it is time to find out how to load Metatrader 4 on your forex VPS service.
How to Load Meta Trader 4 on your VPS?
Step 1) After signup and ordering a forex VPS you will get an e-mail from vpsforextrader.com Support Team with an IP address, username, and password to connect to.
Step 2) Now, to load Meta Trader 4 on your VPS, open the remote desktop connection program in windows. You can usually find it in your Start Menu under Accessories. It should look something like this:
Step 3) Enter your IP for your VPS and your username, then it will prompt you for your password when you press connect.
Step 4) you should now be connected to your VPS and a fresh empty windows desktop should appear. All that’s left now is to download Metatrader 4 platform installer from your broker. So browse to your broker’s website, and find the download link.
Step 5) once you have Metatrader 4 installed, you will want to get your expert advisor(s) on to the VPS. The easiest way I find to do this is using the local resources tab on the Remote Desktop Connection like so.
Click the options arrow like shown below…
Now click on the local resources tab and you will see this below…
Then click the more button show above under local devices and resources and you should get this…
Checkmark the drives you want to share with your VPS and click OK. Now you’re done and can transfer files between your desktop and your Forex VPS.
Step 6) Install the expert advisor into your Metatrader 4 experts folder and then start the MT4 terminal.
Step 7) Attach the EA to the appropriate charts, and you’re done! Congratulation. You load Meta Trader 4 on your VPS.
Note:
If you want your MT4 terminal(s) to autorun whenever the VPS gets restarted, then just create a shortcut in the following directory. C:\Documents and Settings\Administrator\Start Menu\Programs\Startup
If you want to install multiple MT4 instances e.g. from “KLMNOP US demo”, then just change the install directory to something like C:\Program Files\Metatrader 4 KLMNOP US 2\
