Which VPS Control Panel to Choose?
Mike
Hey guys,
I'm looking for a good control panel to use.  I know of SolusVM, HyperVM, Virtualizor etc but which would you consider to be the best?  Looking to use Xen or KVM.
Thanks!
SkylarM
Are you planning to use it for personal use, or as a provider?
Proxmox is awesome, not so hot on the client end if you plan to use it in place of SolusVM as a webhost unless you run an API through WHMCS/etc. I'm using Proxmox for a few personal things and absolutely love it.
XFS_Duke
XFuse Solutions, LLC
I personally think SolusVM is the way to go.
HyperVM looks promising... Just don't like the interface too much myself...
Supicioso
Indeed. I hear HyperVM is pretty decent, but the interface is... shitty to say the least. had it been better, it'd be more attractive. Looks thrown together. Lazily.
My opinion, either proxmox or Virtualizer. With what just happened to solus. I'd stay away. At least for the time being.
Mike
Virtualizor looks quite good and is quite cheap like it's sister, Softaculous.
XFS_Duke
Looking at Virtualizor, looks nice. Might have to test it out a little.
earl
anyone ever use onapp?. seems they have a free version that allows you to use XEN, looks pretty interesting, not sure how hard to setup.
http://onapp.com/pricing/
Just to add, if virtualizor is anything like webuzo I would probably stay away.. I know a few provides that use to offer virtualizor and they seemed to have moved on to solus so I'm sure it had it share of problems but that was years ago not sure if they have gotten any better. At the time I did like virtualizor more than solusvm cause it had a lot of features that solusvm was lacking.
Reece-DM
OnApp is lovely, though its more targeted for cloud operations.
I know @Jhadley has an Onapp setup, not to sure about the HA side of things.
lv-matt
OnApp is pretty good, I am giving the free version an install on some hardware I have sitting around for testing.
DaringHost
Virtpanel is also out there, although I've never used it before. I believe Burstnet uses it as their VPS control panel. According to their documentation it can be integrated with WHMCS and HostBill.
We've used both SolusVM and HyperVM and as already stated SolusVM is the "prettiest" out of them. Both work though.
jhadley
OnApp is fantastic if you can afford it or strike a deal with the sales reps (don't just plan to use the free version - you will outgrow it quickly). I don't have HA set up and it still works fine, but if I were redoing everything I'd probably go for HA with their new Storage option.
SkylarM
pretty sure burstnet uses vePortal.
concerto49
I think that's the only problem here - price. Solus' low price has kept everyone on board.
Burst are veportal's only customer pretty much. I remember trying it out before. Man did I drink that night.
