X4B | Asian DDoS Protection | $14 for a Limited Time | TKO, SGP, AMS, LON, MIM, ASH, DAL, LAX
X4B DDoS Protection is proud to announce to launch the first release our Premium Anycast DDoS Protection line focussing on protection in the underserved Asia market.
AS136165: The network
Current PoPs:
  • Amsterdam, Netherlands
  • London, United Kingdom
  • Los Angeles, CA, USA
  • Dallas, TX, USA
  • Ashburn, VA, USA
  • Miami, FL, USA
  • Tokyo, Japan NEW
  • Singapore, Singapore NEW
Looking Glass: https://lg.x4b.net/ (103.249.70.2)
The Deal
Product Line: Premium Anycast DDoS Protection
Protection: 100Gbps / 100Mpps Guarunteed, 200Gbps / 200Mpps Burstable
Clean Bandwidth included: 25GB (upgrades available)
Coupon: LE30PCT (30% of Premium Anycast line)
Price: $14 (with coupon: LE30PCT)
Valid Until: 15/06/2019 (unless we sell out)​
Order Link
You won't find comparable DDoS protection in Asia in this price range.
The 20 Questions:
Are you actually offering protection in Asia?
With a total network capacity over over 3Tbps and growing we have sufficient capacity to mitigate most attacks locally in Asia. We do however depend on our Anycast network (particularly L.A) to help take the brunt of larger than 100Gbps attacks or in times of network stress.
Why Anycast?
An anycast network is more redundant, and fault resilient than a regular single PoP network. By announcing in multiple distinct locations we gain redundancy against network and server failure as well as the ability to reduce latency by taking in the connection closer to the source.
Anycast also allows for an increase in Mitigation capacity (particularly Layer 7) and overall throughput per service.
Can I point one or more Anycast PoP at a single server?
Yes you can select which Anycast PoP should be forwarding to each defined backend.
Can each PoP communicate with my server direct?
Yep.
Optionally with GRE Tunnelling you can also choose to have all PoPs pointed at a single backend, and for that backend to communicate with the appropriate PoP all via a single internal IP address; or you can define only a single tunnel (the choice is yours!)
This is an Anycast IP, can I connect out?
We have worked hard to build a solution that is able to function in every way like a regular Remote Protection service. With a GRE tunnel you can make outgoing connections. There may be a small delay for the first few packets while we create an optimized route through the network.
What about Support?
Low End plans have support Priority capped at Medium. Support for Low End plans is provided in a reduced capacity.
