I do like lighttpd. It is easy to setup and is running with low resources.
This tutorial will show some nice config featues of lighttpd.
Quite simple if you look e.g. to the apache configuration.
- basic configuration
First of all there is a macro doing all the config stuff for you. Enabling a mod, including the list of available mods, is quite easy:
lighttpd-enable-mod
Available mods are:
Code:lighttpd-enable-mod Available modules: auth accesslog cgi evasive evhost expire fastcgi flv-streaming no-www proxy rrdtool simple-vhost ssi ssl status userdir usertrack fastcgi-php debian-doc Already enabled modules: auth accesslog cgi fastcgi proxy ssl status fastcgi-php Enable module:
The default lighttpd.conf looks like this:
/etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_alias",
"mod_compress",
"mod_redirect",
#"mod_rewrite"
server.document-root = "/var/www"
server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
server.errorlog = "/var/log/lighttpd/error.log"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
index-file.names = ( "index.php", "index.html",
"index.htm", "default.htm",
" index.lighttpd.html" )
url.access-deny = ( "~", ".inc", ".dat" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
## Use ipv6 if available
#include_shell "/usr/share/lighttpd/use-ipv6.pl"
dir-listing.encoding = "utf-8"
server.dir-listing = "disable"
compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ( "application/x-javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
Only thing to change: server.dir-listing to "disable"
- https configuration
Done in conf-enabled/10-ssl.conf
$SERVER["socket"] == "0.0.0.0:443" {
ssl.engine = "enable"
ssl.pemfile = "/etc/lighttpd/server.pem"
Just likt to the pem file. That's it.
- php configuration
Done in conf-enabled/15-fastcgi-php.conf
Code:fastcgi.server += ( ".php" => (( "bin-path" => "/usr/bin/php-cgi", "socket" => "/tmp/php.socket", "max-procs" => 2, "bin-environment" => ( "PHP_FCGI_CHILDREN" => "1", "PHP_FCGI_MAX_REQUESTS" => "1000" ), "bin-copy-environment" => ( "PATH", "SHELL", "USER" ), "broken-scriptfilename" => "enable" )) )
- auth configuration
Can be done in conf-enabled/05-auth.conf or in lighttpd.conf. Depends on your way to keep the config files clear...
Code:$HTTP["url"] =~ "^/important/" { auth.backend = "htpasswd" auth.backend.htpasswd.userfile = "/etc/lighttpd/.passwords" auth.require = ("/important" => ( "method" => "basic", "realm" => "important", "require" => "valid-user" )) }
- proxy configuration
Can be done in conf-enabled/10-proxy.conf or in lighttpd.conf. Depends on your way to keep the config files clear...
Code:$HTTP["host"]=~ "domain1|domain2" { proxy.balance = "fair" proxy.server = ("" => ( ( "host" => "127.0.0.1", "port" => 4001 ), ( "host" => "127.0.0.1", "port" => 4002 ) )) }
- host based configuration
Done in lighttpd.conf
$HTTP["host"]=~ "domain.org" {
server.document-root = "/var/www-org"
Set host and document root.
