Howdy guys,
So this has been a consistent problem for me and I'm wondering if anyone else has any idea behind what this issue could be.
After installing Debian on the SD card with my Raspberry Pi, after an extended use the SD card has an IO error (corrupted data). This has happened multiple times ever since I had my Raspberry Pi B+. Anyone else have similar issues? Anyone found out what the solution is? Raspberry Pi's forums all suggest the same things, power supply, power source, bad quality SD card, etc. However everything is genuine and within specs and I can guarantee are within proper specs. Anyone have any other ideas?
Thanks!
Thanks!
