Anniego Server
SHARED HOSTING
Pricing Plans
The most affordable yearly and monthly plans
ANNIEGOPricing Plans
Starting At$4.99 (Monthly)
Single Domain
Unlimited Disk Space
Unlimited Data Transfer
Unlimited Email Accounts
MOMMY
Starting At$10.99 (Monthly)
3 Domains
2 Email Accounts
Renewals at $2.99
DADA
Starting At $14.99 (Monthly)
Unlimited Domain
Renewals at $4.49
ADVANTAGES
ECONOMICAL
Shared hosting cost less compared to vps or dedicated server because you are sharing the space with other users. The space depends on the plans you subscribe under Shared hosting service.
CONVENIENCE
Client doesn’t need to have the technical know-how. You can manage you website without worrying of the technical aspect of it because the hosting provider will handle it administration duty for you.
MAINTENANCE
When you subscribe to shared hosting, the hosting provider will take care of the maintenance. They will monitor your site and fix the problems when it occurs.
WHY SHARED HOSTING
Shared hosting is cheaper compared to VPS and dedicated. For small time business website or personal blogsites, shared hosting is highly recommended. In shared web hosting, there is no need to concern yourself in case technical difficulties occur on your server, the hosting service provider will taking care of the administration and maintenance of the server.Click for full details: https://www.anniegoserver.com/shared-hosting.html
VPS HOSTING
Upgrade to a better and faster web hosting.
ANNIEGO-VPS Upgrade to a better and faster web hosting.
Starting At $39.99
2 CPU Cores 30GB Disk Space
2GB RAM
1TB Bandwidth
MOMMY-VPS
Starting At $69.99
2 CPU Cores 60GB Disk Space
4GB
1 Additional IP
2TB Bandwidth
DADA-VPS
Starting At $100.99
3 CPU Cores
120GB Disk Space
6GB RAM
1 Additional IP
3TB Bandwidth
ADVANTAGES
Power-packed Performance with our Linux KVM VPS .ENHANCED CPANEL
Every VPS server configuration includes the highly acclaimed ‘enhanced cPanel’ interface. It features everything you need to deliver.!
POWER & PERFORMANCE
Kernel-based Virtual Machine (KVM) is a virtualization infrastructure for the Linux kernel that turns it into a hypervisor, a program that allows multiple operating systems to share a single hardware host. With KVM, we offer VPS hosting that is both powerful and easy to use, and by building our servers with state-of-the-art components, we unlock truly breakthrough speed.!
INSTANT PROVISIONING
Get your VPS server up and running in seconds! Whereas most VPS hosting solutions take hours or days to be activated, our VPS servers are designed to be provisioned immediately. This way, your server is ready, right when you need it.!
IN A NUTSHELL
Compared to shared hosting, VPS hosting allows the subscriber to gain full access to the VPS’s OS, with unrestricted root or administrator permission. Because of this there are no other websites on your server that potentially have access to your files. VPS hosting has a dedicated amount of RAM available. VPS imitates a dedicated server within a shared hosting.Click for full details: https://www.anniegoserver.com/vps-hosting.html
DEDICATED HOSTING
MOMMY-S1
Starting At $190.99
i3-Dual Core -3.06Ghz H/T
8GB DDR3
2 x 1TB SATA2
100Mbps, 20TB Included, $0.25 x
APC Remote Reboot Port
KVM Over IP on demand
Linux - CentOS 6 - 64 bit
Ssh (Linux) or Remote Desktop
Ping Monitoring
29 IP Address
Ready within 10-15 mins.
ANNIEGO-S1
Starting At $170.99
Core 2 Quad 2.4GHz
8GB DDR2
1,000GB SATA2
100Mbps, 12TB Included, $0.25 x
Ping Monitoring
Up to 6 usable IP addresses
Ready within 48hrs
DADA-S1
Starting At $300.99
Intel® Core™ i5-2500
8GB DDR2
1TB SATA2 + 1TB SATA2 + RAID1
Ping Monitoring
Up to 30 IP addresses
AGS-005
Starting At $79.99
Core 2 Quad 2.4GHz
4GB DDR2
300GB SATA2
Ping Monitoring
Up to 1 usable IP addresses
Ready within 48hrs
AGS-006
Starting At $89.99
Core 2 Quad 2.4GHz
4GB DDR2
300GB SATA2
Ping Monitoring
Up to 2 usable IP addresses
Ready within 48hrs
AGS-007
Starting At $110.99
Core 2 Quad 2.4GHz
8GB DDR2
1TB SATA2
Ping Monitoring
Up to 3 usable IP addresses
Ready within 48hrs
AGS-008
Starting At $120.99
Core 2 Quad 2.4GHz
8GB DDR2
300GB SATA2
100Mbps, 12 TB Included, $0.25 x
Linus -CentOS 6-64 bit
Ping Monitoring
Up to 4 usable IP addresses
Ready within 48hrs
AGS12017
Starting At $150.00
Core 2 Quad 2.4GHz
8GB DDR2
1,000GB SATA2
Ping Monitoring
Up to 5 usable IP addresses
Ready within 48hrs
ADVANTAGES
ISOLATED
The top advantage of subscribing a dedicated server is that you will not share the resources of the server to the other clients. You don’t need to worry about other sites congesting the RAM and CPU of the server. Dedicated server assures you the security you need. Compared to shared hosting, website that shares with your resource may access your files.
FLEXIBLE
Dedicated server gives you the ability to fully customize the server depending on your needs for RAM, CPU, disk space and application. Dedicated server is like owning the entire house, you can set things up however you like.
UNIQUE IP ADDRESS
Every server has a unique IP address. With shared hosting, you share the same IP address to the other website in that server. Your SEO rank might be on the risk if your neighbor website in that server happens to be a spam site or an adult site. A unique IP address is vital especially if you are running an ecommerce site which requires security for every transaction.
Click for full details: https://www.anniegoserver.com/dedicated-hosting.html
Visit our webiste and keep in touch with us www.anniegoserver.com
