• Announcements
    • MannDude
      -MannDude
Help building low-power server with e-sata raid
7 posts in this topic
I bought a ZBOX Mini PC and added a old 128GB SSD and a old 4 GB of RAM. Perfect setup for a small Windows-alike plattform.
Main purpose is a running Windows 2012 R2 server for .Net / AD / IIS stuff. I really like the fan-less build and the low-power footprint of this bare-bone.
But I would like to add a SATA based raid with two 512GB Sata3 drives (which are currently idling on my desk). The box does have an external e-Sata port so my guess would be that it might be possible to connect "something" on that port that would be able to handle 2 or 3 SATA drives. But I did not find anything below my hobby-190$-limit.
Sharkoon does have a e-Sata raid box: https://en.sharkoon.com/product/1689/11353 but that is a oversized 5-bay solution. Maybe someone is allready working with a low-budget Raid-1 solution.
1 person likes this
Share this post
Link to post
Share on other sites
8 minutes ago, HalfEatenPie said:
Well, on a real big budget iirc @TheLinuxBug mentioned on his ARM device post that he's using a software raid card that's was basically a port multiplier.
I think this was the one: http://www.amazon.com/Syba-Internal-Multiplier-Mounting-SY-PCI40037/dp/B0056HNROI
Can you use something like that?
Quick correction; The SYBA JMB393 is actually self-contained storage processor chip which completely frees up the main CPU loading, and is not software raid based.  It can be used as a port multiplier or a RAID card based on the configuration you used for it.  I currently use it as a raid5 controller for 5x2TB SATA on my pcDuino Nano A20 as it is limited to a single SATA port.
Before I add anything else though, I just want to mention it is SATA II and will likely not work for your needs (SATA 3, I am assuming you want 6Gb/s while this only supports 3Gb/sec).
If all you wanted was to add additional storage (which doesn't look to be the case here) you could also just get a $25 SATA II port multiplier off of ebay (dont have a link currently but if you search you will find it quickly).
I can't currently think of something to offer for your needs as honestly I have built most of my storage solutions my self, so I haven't looked much at the Pre-built NAS boxes that are out there.  I think @KuJoe has messed with a few though? Could be wrong...
Cheers!
2 people like this
Share this post
Link to post
Was looking around and found two board which I thought may be interesting for this thread:
LeMaker Cello($299.00 & still need to purchase DDR3 Ram)  and the NVIDIA JETSON TK1 ($192.99 w 2GB Ram)
LeMaker Cello
SoC AMD Opteron A1100 Series
CPU Quad-core ARM Cortex-A57 64 bit
DRAM Two DDR3 SO-DIMM sockets
SATA Two SATA ports
USB Two USB 3.0 ports
Console USB-micro port for console support
Ethernet 1 GBe Ethernet
PCIe x16 PCIe G3 slot
JTAG 10-Pin JTAG headers
Expansion Interface Linaro 96Bords Expansion slot
Dimension Standard 160 x 120 mm 96Boards Enterprise Edition form factor
Weight 500g
The LeMaker Cello main board is scheduled to ship in Q2 of 2016.
It will however have Usb 3.0 AND SATA w/ Gigabit Nic and DDR3 sockets so potential for a reasonable amount of memory (more than the 1-2GB we have been seeing I would hope).
NVIDIA JETSON TK1
Model
Brand
NVIDIA
Model
940-7R375-0001-000
Combo Type
Motherboard/CPU/VGA Combo
Bundle
CPU
NVIDIA 4-Plus-1 quad-core ARM Cortex A15 CPU
Memory
2GB memory with 64 bit width
16GB 4.51 eMMC memory
Expansion Slots
Mini Card Slots
1 x Half mini-PCIE
Storage Devices
SATA
1 x SATA
Onboard Video
Onboard Video Chipset
NVIDIA Kepler GPU with 192 CUDA cores
Onboard Audio
Audio Chipset
Realtek ALC5639
Onboard LAN
LAN Chipset
Realtek RTL8111GS
LAN Speed
10/100/1000Mbps
Rear Panel Ports
COM
1 x RS232 serial port
HDMI
1 x HDMI
USB 3.0
1 x USB 3.0
Audio Ports
2 Ports
Internal I/O Connectors
Other Connectors
1 x Full size SD/MMC connector
1 x JTAG
1 x 12V DC Power
The following signals are available through an expansion port
-DP/LVDS
-Touch SPI 1x4 + 1x1 CSI-2
-GPIOs
-UART
-HSIC
-i2c
Both include real SATA on board and USB 3.0 and would be great for a server solution you could probably trust (more than a $15 board maybe :) ).
Cheers!
1 person likes this
Share this post
Link to post
Definitely interesting boards.  However, pricing on these has them up above Intel complete NUC and J1900 type boards with full cases and all.
Not kicking either effort, just unsure if the value is there to justify those asking prices or even 50% of such.
Share this post
Link to post
I'd be interested in build notes / photos on your A20 + 5 drive setup.
How long have you been running it and how reliable has it been so far?
Share this post
Link to post
  • Similar Content
    • By TurnkeyInternet
      TurnKey Internet, Inc provides dedicated servers, colocation, web hosting, cloud, and virtual servers from it's company-owned and operated green datacenter. Since 1999, TurnKey Internet, Inc. has built a reputation of outstanding personalized service, reliability, and value. Owning our own datacenter lets our on-site 5-star rated staff answer your questions quickly and provide complete solutions direct from our expert team located right in the same building as your servers.  We are experts in the Cloud Hosting and Datacenter space with a true dedication to your online success every step of the way.
      Turnkey Best Value Deal : Save over $9,000 from the competition! This *All New* Best Value deal dedicated server is 200% more powerful than the competition. You will save over $9,000 a year compared to what competitors would charge you for same amount of server power, and TurnKey offers a 30 day money back guarantee on top of these amazing best value deals. Visit the comparison data on our web site to see how TurnKey provides you the most server value for your money.
      FREE Website & Server Migrations : TurnKey Internet makes migrating to our cloud and web hosting services easier than ever by handling all the migration work for your website(s) and servers including all email, databases, websites, and applications. More Information
      256 GB Dell Poweredge Dual Octa-Core E5-2660 Dedicated Server Special (32 Cores x 2.20 Ghz!)
      Enterprise Grade Dell PowerEdge Servers Qty 2 x Intel  Dual Xeon E5-2660 Octa-Core CPUs @ 2.20 GHz (2 CPUS x 8 Cores @ 2.20 GHz) Hyperthreading (HT) Enabled 32 Visible Cores (16 Physical Cores + 16 Via HT) Intel Virtualization Technology (VT) Enabled 256 GB Ram  Raid 10 (4 Disk System) with 4 x 240 GB SSD Included! Un-Metered Bandwidth *GigE* 1000 Mbit / GigE Port Included    IPv4: 5 Usable IPs on /29 via Cisco Dedicated Layer 3 port    IPv6: /64 Subnet included    RAID: optional Raid 1/5/10 Upgrade Available Configure up to 4 Total Disks - for Raid 1/5/10 Choice of Linux or Windows operating systems Free Web Reboot Port 100% network uptime guarantee 24x7 toll-free phone, live chat, and help desk support   30-day money back guarantee   NO SETUP FEES  No Term Contracts!
      $279/month (no setup fees) Best Value Deal with coupon 'bestvalue' | Order Now   Additional 10% Off For Life when you pre-pay Annually!  That's just $250/mo
      This *Best Value* dedicated server deal is a dedicated physical server located in our New York company owned datacenter directly connected via a dedicated Gigabit internet port.  You get the entire server physically provisioned and dedicated to your organization to setup whatever software you want. You can run Windows Server 2012, or install a hypervisor virtualization operating system such as VMWARE or Xen / KVM and create VPS's, or use linux and cPanel for an amazingly powerful web hosting server.
      The price may look unbelievable, it is our investments in our company-owned green datacenter that lets us operate at lower costs than the competition to provide these amazing values to you and still maintain a profitable company that has been around since 1999. To learn more about TurnKey please visit https://turnkeyinternet.net/about.
      Additional costs for certain control panels, hardware or software add-ons, features, or operating systems may apply - please see order links above and shopping cart for options.
      View Our Virtual & Cloud Server packages   |  View Our Fully Managed Virtual & Cloud Server packages
      About TurnKey Internet:
      All servers are hosted in our company-owned and operated, ENERGY STAR certified,  green data center in New York’s Tech Valley Region. Alternative technologies such as on-site solar power generation, cold containment pods, hydroelectricity, and SmartAisle cooling have eliminated our carbon footprint entirely, and made our datacenter the best of the best for energy efficiency nation-wide.
      Since 1999, TurnKey Internet has built a reputation of outstanding personalized service, reliability, and value. We are experts in the Cloud Hosting and Datacenter space with a true dedication to your online success every step of the way.  TurnKey maintains an A+ rating from the Better Business Bureau, is SSAE 16 Type 2 certified, ENERGY STAR certified, and the winner of the 2012 Excellence in Small Business Award from the U.S. Small Business Administration.
      Don't just take our word for it - view these Verified Client Testimonials and our 5-star, perfect rating from Shopper Approved.
      CONTACT US:
      Live Chat: Live Sales Chat
      Email: [email protected]
      Web: www.turnkeyinternet.net
      Facebook: Turnkey Internet
      Twitter: @TurnKeyInternet
    • By dcdan
      5x Dell C1100 servers for sale @ Phoenix NAP
      Dual Xeon L5639 CPUs
      72 GB DDR3 ECC 1066 MHz RAM
      4x 3.5" drive trays with support for 2.5" drives w/o adapter (no drives included)
      Latest BMC ver 1.82
      Rails
      All servers have been working for 2 years without a single hiccup.
      $200 each ($1000 for all 5).
      Sorry, cannot split or ship. Local pickup @ PhoenixNAP ONLY on May 26 at 4 PM (see clarification below)
      Paypal or credit card payments are accepted from established members with at least 12 months of activity on the forum. Otherwise cash or wire.
      P.S. We have plenty of 1TB SSD drives in excellent condition to go with servers if needed (extra $).
      4x EX3200-48T switches for sale @ QuadraNET Los Angeles
      All come with JunOS v12 and rack ears
      All switches have been pulled from working environment.
      $150 each ($600 for all 4).
      Sorry, cannot split or ship. Local pickup inside QuadraNET L.A. in person, near our cabs ONLY on May 30 at 4 PM. Exact location will be provided.
      Contact via PM
      Clarification: This has to be picked up in person. Sorry we cannot ship or transfer to other clients within same datacenter. You need to have access to the datacenter and take the hardware straight from our hands (near our cabs) on the dates above. At PhoenixNAP we can carry outside to the parking lot at 4 PM, but at QuadraNET this is not an option.
    • By fizzyjoe908
      Hey guys,
      We have some hardware currently located in Chicago that we are looking to sell as a lot. We are not really interested in entertaining offers for individual items, but we do need to make a sale here. I'm open to discussion :)
      Here is a general description of what's available:
      11x 1U HP or Dell servers ( no drives included, rails included ) 3x 2U Dell servers ( no drives included, rails included ) 1x HP switch 1x PDU 1x Lantronix spider KVM 26x HDDs and SSDs Since there's quite a bit of hardware available and it's a lot sale, I don't want to get too specific with individual pieces. However, if you are interested, please PM me and I will provide you with a PDF containing a full hardware inventory and price breakdown.
      This hardware can be shipped from New Continuum Chicago ( zip code 60185, buyer arranges shipping, not included in price ) or colocation there can be continued. Payment can be made via wire transfer (preferred) or PayPal.
    • By drmike
      Excellent security dev here done by this gent to show weakness in Tor.
      Simply said, bits of data available even with Tor bundled browser originating from mouse and other hardware.  Enough to make you think plausible to use such to identify user as being the same user seen elsewhere. Over time, who knows more data and more screwed.
      Screams for more emphasis in general on dumping javascript and severely limiting viewing methods if you are sane and inclined to care about being profiled and silo'd.
      UberCookie
      During the last weeks I have been able to fingerprint tor browser users in controlled environments and I think it could be interesting to share all the findings for further discussion and to improve tor browser.
      All the provided fingerprinting methods are based on javascript (enabled by default in tor browser as of today). I have created a quick and dirty PoC called UberCookie available as a demo here:
      Try ubercookie : http://jcarlosnorte.com/assets/ubercookie/
      Source: http://jcarlosnorte.com/security/2016/03/06/advanced-tor-browser-fingerprinting.html
    • By HN-Matt
      You can view the different levels and their various pros and cons @ http://www.ibeast.com/content/tools/raidcalc/raidcalc.asp
