We would like to introduce ASYD, i hope i used the correct forum - it's open source so should fit.
ASYD is an automation system for the deployment of IT infrastructure and server monitoring, similar to Puppet and Chef (plus additional functions)
It is powerful and agentless (only needs SSH) as well as fully opensource, it comes with an integrated web interface making it even easier to manage and visualize all your systems. ASYD also offers server monitoring (via Monit) and automatic recovering of services (based on Monit also), which makes it the perfect all in one solution for managing your entire infrastructure.
With ASYD, system administrators can easily install software, updates, manage settings, or monitor the status of their servers on a comprehensive, quick and easy way, without requiring any programming skills, just a basic knowledge of shell scripting and a fancy webinterface.
Reading the entire documentation doesn't takes more than 10 minutes, and writing deploys for automating your systems is just as easy. Thanks to the variables and conditionals, you just need to write a single deploy which will work on any kind of system (BSD+Linux+SUSE+others), and with our custom syntax you can do all that in just a few lines.
You can see more info or get it in our website, www.asyd.eu
We would also love to get some feedback
Album with screenshots: http://imgur.com/a/vdN8X
Disclosure: i am affiliated with ASYD Solutions S.L.
