Best place to find coders?
drov
I am a web developer and have a vast network of developers in all languages. I look to them when work comes along.
I can refer some to you if you'd like.
Sent from my iPhone using Tapatalk
Hiring depends.  Depends on what role you are in and what you are looking to hire.
I prefer to deal with known to me people first.  That would be in real life regional people in my peer group.  Second, I consider online connections.  Finally, everything else.
Craigslist can be alright for regional.
The everything else is probably best with Odesk at current.
This is a good read on hiring programmers in particular:
http://blog.codinghorror.com/how-to-hire-a-programmer/
libro22
If you don't mind hiring non US/EU coders, odesk.com is extensively promoting themselves in SEAsia so you may find a lot of options there.
comXyz
What kind of project is it? What language? You can look for good programmers in programming forums.
Tyler
Try elance, I mean they all are the same anyways.
Could not be further from the truth. A good developer vs a bad developer will make the world of a difference. Great developers can help make the project a success, and bad ones can kill the project.
Do your research. I would recommend guys on industry forums - it shows that they're learning and at the top of their game.
HBAndrei
I wouldn't trust people from fiverr, elance, freelancer, etc with a serious coding project.
You should look for companies in your city/country, companies that you can actually meet face to face and discuss the project, terms, deadlines, concerns, etc.
fixidixi
0. question: #define good developer
The golden triangle:
-precise, "makes it right"
-fast
-cheap
you can choose 2 of those traits :)
