Best way to copy DNS from one provider to another (CF to RS)
shovenose
I'm switching my DNS for shovehost.com from CloudFlare to Rackspace Cloud DNS.
I have sooooo many DNS records it's not even funny.
I don't want to enter them again.
How do I copy it, or at the very minimum get a complete list of DNS on CloudFlare (problem is I can't log in to cloudflare.com)...
Thanks!
PS: CloudFlare sucks, Rackspace rocks!
fizzyjoe908
It's impossible to get every single record without DNS transfer rights on the DNS server - which you don't have with Cloudflare. You will need to regain access to your account or there's nothing you can do.
Ruchirablog
CLoudflare supports exporting/importing DNS zone files. Dont know if Rackspace supports importing them. But Amazon Route53,Linode DNS supports them.
Raymii
Long story involving two factor authentication. Doesn't matter.
You lost your phone and do not have any backup codes like With google? Seems like you're lazy with your stuff...
Time to Start running bind yourself mate, would fix this issue for you..
shovenose
It's a little more complicated than that. I'm not lazy and I didn't lose my phone. Regardless, I manually put in a bunch of them and hopefully didn't miss any.
lbft
Can you not recover your Authy account? There are recovery options on their website...
Ree
You don't like them because you're locked out, or did you have service issues with CF?
I was using Point until a couple weeks ago, but after the Copper.io buyout figured I better get out before they get rid of the free plan (which I just got an email about this morning -- totally saw that coming from a mile away!).
So long story short I just switched to CF, so I'm curious to hear if anybody has had issues with their DNS.
shovenose
Rackspace Cloud DNS is free, and in my opinion faster than CloudFlare's because even when you turn all the extra crap off it still is a more complex system.
Dylan
Speed is measurable and CloudFlare's DNS is objectively faster than Rackspace's (almost 10x faster). The only DNS providers in the same league when it comes to speed are Dyn and DNSMadeEasy.
http://www.solvedns.com/dns-comparison/2013/09
shovenose
Well my website feels significantly faster after the switch, and Rackspace's customer service is so phenomenal that it would make up for slightly slower performance.
