Building a CDN?
BlackoutIsHere
So I was bored and started thinking about building a CDN with cheap VPSes. I was thinking something like latency based routing combined with rsynced nginx machines would make a pretty simple but fast CDN. Has anyone tried this and would anyone be interested in using a service like this? Also does anyone know of a good method of global bandwidth accounting?
Thanks,
Blackout
manacit
An alternative to using rsync would be making an origin-pull based system where each edge instance proxies back to a master node that has the content. On first load, it would need to call home, but after that, it would cache the content for as long as you set, and serve as an edge node.
For bandwidth accounting, you could always reverse proxy nginx to a local app that you run which would account for files accessed and bandwidth used, and periodically call home with totals, etc. Alternatively, log analysis could easily net you a bandwidth total.
Slownode
Making a simple file server CDN is pretty trivial; load balancing, file mirroring, receiving, usage monitoring.
A week's work can make something quite powerful.
Distributed databases on the other hand can be very challenging.
BlackoutIsHere
