Coding contest: Community driven ping/traceroute project
BlueVM
@bcarlsonmedia - 3 to 6 weeks. Maybe a tad bit longer as I'm getting ready to move.
I saw version 2.0 of Telephone's looking glass.
Looks fantastic and I believe it does everything we've been trying to make here?
I did not know both projects. Both look really good:
  1. https://github.com/mojeda/ServerStatus
  2. https://github.com/telephone/LookingGlass
And I don't like the idea to reinvent the wheel.
My current favorit is LookingGlass. It has:
  • Commands (all nedded ones)
  • IPv4 & IPv6 support
  • Rate limiting
Only thing to add:
  • GitHub hosted file with list of other nodes
  • An additional pulldown box for the list of nodes.
  • A config option to use an internal or the external list of nodes.
NodeBytes
Dedi Addict
So what about merging the 2 and forming exactly what would be needed most for the community.
I was thinking of putting a status page that monitors all the nodes as well and a script that removes them from the list when they are down.
mojeda
If anyone is interested I just finished up implementing ServerStatus with LookingGlass.
It's currently dev only so it's not in the master branch of ServerStatus. https://github.com/mojeda/ServerStatus/tree/dev
To get it to work upload the new uptime.php to the same folder as LookingGlass' index.php: https://github.com/mojeda/ServerStatus/blob/dev/uptime.php
Then replace/upload LookingGlass files with: https://github.com/mojeda/ServerStatus/tree/dev/LookingGlass
You should get the following LookingGlass page:
The Server Status section will update every 15 seconds.
If you don't have LookingGlass, you can get it here: https://github.com/telephone/LookingGlass
Also implementing this will not break the Master ServerStatus script.
