Nogics Technologies
Nogics Technologies presents dedicated server plans which suits most of you. It's based on Intel XEON with Gb's of RAM. The best thing about our dedicated server plans is it's 6 hours express delivery.
# Dedicated 1
- Intel Xeon E3-1220LV2
- 2.3 Ghz Quadcore (4 Cores)
- 4 GB RAM
- 2X1 TB RAID 1 HDD
- 5 TB Bandwidth
- 2 IPV4 + 5 IPV6
- Price: $125.12 USD
Order Here
# Dedicated 2
- Intel Xeon E3-1265LV2
- 2.5 Ghz Quadcore (4 Cores)
- 4 GB RAM
- 2X1 TB RAID 1 HDD
- 5 TB Bandwidth
- 2 IPV4 + 5 IPV6
- Price: $155.15 USD
Order Here
# Dedicated 3
- 8 GB RAM
- 2X1 TB RAID 1 HDD
- 10 TB Bandwidth
- 2 IPV4 + 5 IPV6
- Price: $185.18 USD
Order Here
# Dedicated 4
- Intel Xeon E3-1230LV2
- 3.2 Ghz Quadcore (4 Cores)
- 16 GB RAM
- 2X1 TB RAID 1 HDD
- 15 TB Bandwidth
- 2 IPV4 + 5 IPV6
- Price: $225.22 USD
Order Here
Frequently Asked Quesion (FAQ)
Do I get root access to my Dedicated server?
Yes, get full root access, which means you have full administrative control of your server. This means you have complete control of your server, and can choose to install any software you wish to.
What kind of support do I get with my Dedicated server?
Nogics offers two levels of support for your Dedicated Server: Core-Managed and cPanel relevant. All servers come with Core-Managed support, and if you have chosen to purchase cPanel through us, we offer 'additional support options relevant to cPanel.
When will my Dedicated server be ready once I've placed the order?
We use a proprietary provisioning system which ensures that your server is ready within 6 hours.Yes, you read that right - your server is available for use within 6 hours. No 24 hour wait, no setup fees.
What kind of hardware do you use for each Dedicated server?
Our Dedicated servers use the SuperMicro blade chassis, which has a small footprint with reduced power consumption and cooling requirements. These efficiencies allow us to pass cost savings down to you so your costs are kept to a minimum. Our servers are powered Intel Xeon HyperThreaded processors, DDR3 RAM and 7200RPM SATA drives.
What is the speed of the network port/uplink on my server?
We allow speeds of up to 1Gbps on each server's network port.
Do you provide RAID 1 hard drives?
Yes. Each server comes with a 1TB hard drive pair, which is in a RAID 1 configuration. This means that your data is mirrored, so there is a copy on each drive. If one drive fails, you will still have a copy on the other drive. Our hard drives are 7200 RPM SATA drives.
How do I expand the storage capacity on my server?
With our custom in-house Shared Storage device, you can add a near infinite amount of storage to your server. While your server has 1TB of local storage, you can choose to expand this by adding space instantly to your server on our Shared Storage Device. This will be instantly attached to your server as a disk, at which point you can format it and mount it. You can choose to buy anywhere from 50GB to 500GB of storage at a time.
How do I access my Dedicated Server?
There are several ways to access your server: SSH - you can access your server through any SSH client using the root credentials we provide to you cPanel - if you have chosen to purchase cPanel from us, you can access and manage your server through the cPanel/WHM control panel Dedicated Server Control Panel - you can also perform frequent operations, such as Stopping, Starting and Restarting your server through our web-based control panel, which comes bundled with every server
Do you offer any billing panels?
Yes, we offer WHMCS as a billing panel for your dedicated server. You can purchase the license from us for a significantly lower cost, and then install it on your dedicated server.
All order paid online will get delivered within 24 hours in maximum. Orders like extra IP addresses requires justification which may delay activation of extra IP space.
# Dedicated 1
- 4 GB RAM
- 2X1 TB RAID 1 HDD
- 5 TB Bandwidth
- 2 IPV4 + 5 IPV6
Order Here
# Dedicated 2
- 4 GB RAM
- 2X1 TB RAID 1 HDD
- 5 TB Bandwidth
- 2 IPV4 + 5 IPV6
Order Here
# Dedicated 3
- 8 GB RAM
- 2X1 TB RAID 1 HDD
- 10 TB Bandwidth
- 2 IPV4 + 5 IPV6
Order Here
# Dedicated 4
- 16 GB RAM
- 2X1 TB RAID 1 HDD
- 15 TB Bandwidth
- 2 IPV4 + 5 IPV6
Order Here
