eslabs
Markdown (GitHub flavored):
## LEMPer Stack
LEMPer Stack is terminal-based LEMP / [LNMP installer](https://masedi.net/go/lemper) and manager for Debian & Ubuntu cloud or virtual server (vps) and on-premise (bare metal).
LEMPer stands for Linux, Engine-X (Nginx), MariaDB and PHP installer written in Bash script, also known as LEMP / LNMP installer. This is just a small toolset (a bunch collection of scripts) that I use to deploy and manage LEMP stack on Debian and Ubuntu server. LEMPer is crafted to support wide-range PHP framework & CMS. It is available as [I]Free Alternative[/I] to the paid control panel such as cPanel, Plesk, CloudWays, Ploi, RunCloud, ServerPilot, etc.
### New Features
- cURL'd installation wrapper
- Installation from cURL as below:
- Development: `curl -sSL https://get.lemper.cloud | sudo bash -s -- install --development`
- Production: `curl -sSL https://get.lemper.cloud | sudo bash -s -- install --production`
- Available parameters:
- `--with-nginx=<version>`, available version: stable, latest | mainline, version-number (e.g. 1.20)
- `--with-nginx-installer=<installer>`, available installer: source | repo
- `--with-nginx-custom-ssl=<custom_ssl-version>`, example: openssl-1.1.1l | boringssl-master | libressl-3.0.0
- `--with-nginx-lua`, compile Nginx with Lua module
- `--with-nginx-pagespeed`, compile Nginx with PageSpeed module
- `--with-nginx-passenger`, compile Nginx with Passenger module (Passenger installation required)
- `--with-nginx-pcre=<version>`, example: 8.45
- `--with-nginx-rtmp`, compile Nginx with RTMP module
- `--with-php=<version>`, available version: 5.6, 7.0 - 7.4, 8.0, 8.1
- `--with-php-extensions=<ext-name-1 ext-name-2 ext-name-x>`, example: imagick igbinary json
- `--with-php-loader=<loader_name>`, available loader: ioncube | sourceguardian | all
- `--with-mysql-server=mysql_server-version>`, example: mariadb-10.6 | mysql-5.7
- `--with-memcached=<version>`, available version: latest | stable | version-number (e.g. 1.6.10)
- `--with-memcached-installer=<installer>`, available installer: source | repo
- `--with-mongodb=<version>`, example: 4.2, 4.3, 4.4, or 5.0
- `--with-mongodb-admin=<username:password>`, username: admin username, password: admin password
- `--with-redis=<version>`, available version: latest | stable | version-number (e.g. 6.2.5)
- `--with-redis-installer=<installer>`, available installer: source | repo
- `--with-redis-requirepass=<password>`, Redis password
- `--with-ssh-port=<port_number>`, example: 22, 2269
- `--with-ssh-passwordless`, enable SSH password-less login (requires SSH public key set up)
- `--with-ssh-pub-key=<public_key_string>`, public key string
- `--hostname<host_name>`, Server hostname in fully qualified domain name format (e.g host.lemper.test)
- `--ipv4=<ipv4_address>`, Server static / public IPv4 address
- `--admin-email=<email_address>`, your stack administrator email (for notification, default Let's Encrypt account, and Mail sender)
- `--fix-broken-install`, fix broken installation (broken apt installation)
- `--dry-run`, run installer in dry run mode (testing)
- `--debug`, run installer in debug mode (more verbose output)
- `--force`, force installation and removal of existing installed software package
- `--guided`, enter guided installation mode
- `--development`, install LEMPer Stack on development or local environment
- `--production`, install LEMPer Stack on production environment
### Support Us
To support our development please submit issue or pull request here https://github.com/joglomedia/LEMPer
