Disk not mounted after install? How to properly mount it?
ICPH
I got physical dedicated server from one reputable server provider. And using their OS image install system i applied debian 6.x 64. Server has 2 SSD and one SATA. I setup software raid 1 during installation on SSDs but i dont see anything that looks like my HDD setup..
I mean server should contain:
#Onboard: Corsair CSSD-F120GB2
DRIVE1 /dev/sda
DRIVE2 /dev/sdb
#Onboard: SAMSUNG HD753LJ (700gb+)
###DRIVE3 /dev/sdc
But this is df -h:
Filesystem            Size  Used Avail Use% Mounted on
/dev/md2               98G  696M   93G   1% /
tmpfs                  12G     0   12G   0% /lib/init/rwudev                   12G  192K   12G   1% /dev
tmpfs                  12G     0   12G   0% /dev/shm
/dev/md1              496M   31M  440M   7% /boot
I have been told that i need to mount 700+GB hdd: "add it to fstab our mount it manually via mount command"
Can you please advice on how to proceed, how to do it properly so its mounted after each start? I thought Debian will setup disks automatically.
tonyg
Did you try a google search?
I am sure you will find the answer in one of the search results.
