DNS Issues (Proxmox + Centos Guest)
blergh
Hello,
I am seeing some issues with a Guest i have that's running CentOS. I can ping it from the outside as well as ping from within the guest, however DNS-queries do not seem to work within the Guest.
Contents of /etc/sysconfig/network-scripts/ifcfg-eth0 on the Guest
DEVICE=eth0
BOOTPROTO=static
BROADCAST=31.204.153.1
HWADDR=D6:01:14:2E:07:ED
IPADDR=31.204.152.XX
NETMASK=255.255.255.0
#NETWORK=31.204.152.1
GATEWAY=31.204.152.1
ONBOOT=yes
Contents of /etc/sysconfig/network-scripts/route-eth0 on Guest
31.204.152.1 dev eth0
default via 31.204.152.1 dev eth0
Random tests on Guest;
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
31.204.152.1    0.0.0.0         255.255.255.255 UH    0      0        0 eth0
31.204.152.0    0.0.0.0         255.255.255.0   U     0      0        0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 eth0
0.0.0.0         31.204.152.1    0.0.0.0         UG    0      0        0 eth0
nc -w 3 -z 8.8.8.8 53
Connection to 8.8.8.8 53 port [tcp/domain] succeeded!
Have i dun goof'd? Halp!
scv
Massive Nerd
Need some more information for this one. Give us the following:
Contents of:
  • /etc/resolv.conf
  • /etc/sysconfig/network
Output of:
  • iptables -L -n
  • host google.com 8.8.8.8
nunim
VPS Junkie
Try adding this to your Guest's /etc/sysconfig/network-scripts/ifcfg-eth0
DNS1=4.2.2.1
DNS2=4.2.2.2
NM_CONTROLLED=no
blergh
DNS1=4.2.2.1
DNS2=4.2.2.2
NM_CONTROLLED=no
No luck with that one, bummer.
As for resolv.conf, it obviously has entries (GoogleDNS for testing).
cat /etc/sysconfig/network
NETWORKING=yes
NETWORKING_IPV6=no
HOSTNAME=tele.xxx.com
iptables -L -n
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
I cannot do nslookups, dig, host or similar as this is a minimal install.
nunim
VPS Junkie
You can grab the repo information from another server an add it to a host file so that you can install dig/nslookup/host etc and go from there.
blergh
why dont  u install the required package? on debian its dnsutils
This guest is Centos, and i would if i could however it is a PITA without DNS. I am looking at manually adding entries to the hosts-file in order to fetch these packages tho.
fixidixi
well i think you could do that sooner if u would download the required dependencies:
repoquery --requires --recursive --resolve bind-utils
bind-utils-32:9.8.2-0.17.rc1.el6_4.6.x86_64
openssl-0:1.0.0-27.el6.x86_64
bind-libs-32:9.8.2-0.17.rc1.el6_4.6.i686
bind-libs-32:9.8.2-0.17.rc1.el6_4.5.x86_64
libidn-0:1.18-2.el6.x86_64
krb5-libs-0:1.10.3-10.el6_4.2.x86_64
zlib-0:1.2.3-29.el6.x86_64
libcap-0:2.16-5.5.el6.x86_64
glibc-0:2.12-1.107.el6_4.2.x86_64
glibc-0:2.12-1.107.el6_4.5.i686
libxml2-0:2.7.6-8.el6_3.4.x86_64
blergh
I resolved the issue. The IP was marked as unused at i3d and their automated delegation-process went bananas, automagically blocks 53 + 25 it seems. Got a new IP and the error went away.
