It's likely what we'll go withI think 15% of the plans total cost per month is good!
It's in the worksWhile I've got your attention, I have an off-topic suggestion/wish feature for your Stallion Control Panel. If you could add a status indicator (online/offline) to the Dashboard's Virtual Servers list.
I like the slight performance boost without needing so much disk space.EDIT: Just as I post this, dclardy says he is "really looking forward to the SSD based plans". I should point out, I'm not a "real" sysadmin, just a hobbyist - so don't be too harsh on me. Obviously some people find value in SSD, and I'm not saying I don't think it's valuable - I'm just naive and don't know what the value is.
A base image should easily be doable within 1GB. If using something like SaltStack (or Chef or Puppet), then all you need is a base image set up as a Salt Minion. You could blow servers away all day long and get them back up with little effort.Snapshots would allow the base image idea you haveOnce billing 2 rolls out we'll likely allow 'snapshots only' support and bill it by the GB.
It depends.A base image should easily be doable within 1GB. If using something like SaltStack (or Chef or Puppet), then all you need is a base image set up as a Salt Minion. You could blow servers away all day long and get them back up with little effort.
Not that I'm suggesting anyone should make a sport of "blowing servers away"![]()
