Fiber Optic Switch recommendations
Discussion in 'The Pub (Off topic discussion)' started by drmike, Feb 16, 2016.
  1. drmike
    drmike 100% Tier-1 Gogent
    8,573
    2,717
    May 13, 2013
    Looking at monkeying with fiber here.  Have a spool of fiber and tools for it.  We splice / run fiber in the field, but never have worked with fiber locally like I want to.
    Want to convert at least partially from gigabit ethernet on LAN to faster fiber optic based switching.
    Anyone out there there doing this in their environment?  Imagine it's common in video production shops these days - should be.
    Interested in a switch recommendation.  Most switches are top of rack in nature with a bunch of copper ports then 1-4 uplink fiber ports.  Would like to find something with fiber mostly and no copper perhaps.  Say 8-48 fiber ports.
    Most of the switches I find that fit the bill appear to be for storage devices and blah, exotic, expensive and complicated.
    Anything come to mind?
  2. Jonathan
    Jonathan Woohoo Administrator Verified Provider
    389
    196
    May 27, 2013
    jonspw
    Never used one myself, but you can get Dell S4810 switches for around $2k on eBay and they're loaded with SFP+ ports and even a few QSFP ports for 40GbE.
    HalfEatenPie and drmike like this.
  3. HalfEatenPie
    HalfEatenPie The Irrational One Retired Staff
    2,890
    1,386
    Mar 25, 2013
    Not too related to this, but I know my home router has two fiber ports, then eight Gbit ports.
  4. drmike
    8,573
    2,717
    May 13, 2013
    Yeah the fiber ports on your switch are likely, as mine are, just Gbit.  They are intended for fiber to copper transceivers or such built in.
    Issue with them is obviously throughput stinks.  Gbit copper vs. gbit fiber.  Meh, copper you have 8 Gbit, fiber 2, so a ratio of 4-to-1 and wrong direction in my opinion.  Exactly why those switches and my use are screwy and unsure how other big data pushers cope.  Cause plunking $2k+ down for a switch is damn hefty.
    I'd been fine with like a few Gbps on the fiber ports each, for now.  10Gbps would be great.  Can marry a PCI-X adapter on workstation to fiber and another workstation elsewhere on the same sort of connector and fiber.
    Gig here is to move data now and lots when needed.  Tired of NAS and network stuff taking forever.  Sure I know need drive spindles to go with it. Reason why only needing few Gbps right now, but 10Gbps is super and future proofed for a while.  SSDs are what will be feeding things where I can place them.
    Whole thing is just concept and meh, eventually I'll get it done...
    HalfEatenPie likes this.
  5. Jonathan
    389
    196
    May 27, 2013
    jonspw
    $2k for a 48x SFP+ and 6x QSFP switch is cheap...
  6. drmike
    8,573
    2,717
    May 13, 2013
    Oh I agree it is... all relativity..  Yes, much cheaper than historical.
    Just a hefty chunk to experiment with front side.
    Seeing the power consumption on these fiber switches is rather high.  Better chunk of a KW per hour...
    Definitely need / niche for 8 ports with something like this...
  7. HalfEatenPie
    2,890
    1,386
    Mar 25, 2013
    as if I'd actually ever use a full gbit at home.
    Unless I did some mad work, I don't see that ever happening.
  8. GIANT_CRAB
    GIANT_CRAB New Member
    525
    270
    May 21, 2013
    drmike likes this.
  9. drmike
    8,573
    2,717
    May 13, 2013
    Those are neat.  I somehow missed the multiple SPF models.. 10 of them ;) Tee hee... shame it's just 10 Gbit speed.
    I already use Mikrotik (leisure user of their gear - need to get edumacated on the finer points of their gear ability).  Control stuff for their OS still feels other side of the brain to me'ish.  But I do like.
    Off to look at Cloud Core Routers.
    GIANT_CRAB likes this.
  10. DamienSB
    DamienSB Active Member Verified Provider
    123
    26
    Mar 24, 2013
    Look at cisco nexus 5k
    drmike likes this.
  11. Jonathan
    389
    196
    May 27, 2013
    jonspw
    If you think power for 10GbE Fiber (SFP+) is high, look at a 48-port RJ-45 10GbE switch and then you'll realize how little power SFP+ uses :)
    drmike likes this.
  12. mitgib
    mitgib New Member Verified Provider
    284
    219
    May 15, 2013
    I did just this, found a 40 port used unit on fleabay for $800, it runs my storage network for Ceph, then you can usually find HP Dual (Melenox) 10GbE PCIe cards for ~$50-75 and transceivers for ~$20-30 (service unsupported-transceiver to use non-cisco branded) and patch cables for $2-3
    drmike likes this.
  13. drmike
    8,573
    2,717
    May 13, 2013
    You are the man!  That's the type of prices that make things doable :)
  14. DamienSB
    123
    26
    Mar 24, 2013
    I also strongly recommend that you use fiberstore for any fiber /  SFP purchase. They have a great sales team, specifically i talk and deal with "coco".
    http://www.fs.com/
    drmike likes this.
