Having problems with cPanel and AWStats generation - Can somebody help?
Amitz
Dear all,
I have a cPanel server and - all of the sudden - AWStats stopped generating stats for users. Well, to be more precise: It seems as if it still generates them but with 0 visitors, 0 pageviews, 0 hits and so on. It seems as if the server has stopped generating logs that AWStats could process.
The only thing that I have changed is recompiling Apache with EasyApache to use fcgi as PHP handler instead of suPHP. I "hate" EasyApache and am not too familiar with Apache itself (coming from the nginx world) so I wonder whether it might have something to do with the recompilation.
Did you ever come across that problem or maybe have a solution for me? I searched Google & Co. but did not find the answer to my problem. I have also contacted cPanel support, but those guys could take some time before I even receive an initial response.
Thank you very much for any hint & help in advance!
Cheers,
-A
mikho
Have you checked if it's logging visitors at all or if the problem is when awstats reads the logs?
I suspect that it's not even logging at all.
HostUS-Alexander
Hello,
Run 'service cpanel restart' wait a day, then if there is the same issue, just re run the cPanel updates with force reinstall. Works for such issues.
- Alexander
